PUSH BUTTON STARTER: Ignited?
Old Jan 8, 2008 | 05:29 AM
Da K00l Aid Man's Avatar
Da K00l Aid Man
Default PUSH BUTTON STARTER: Ignited?
I want to install a push button starter in my 03 Touring model. What other sites/companies besides Ignited make a kit for them or a universal kit ?
Old Jan 8, 2008 | 05:33 AM
Lawy'dU's Avatar
Lawy'dU
A kit is being made by a member on G35driver to incorporate the G37 and new G35 sedan's push button starter. It will work on a Z. Definitely run a search there and find it. The kit is done, I just don't know if it has been released to the public. A number of members have it installed already.
Old Jan 8, 2008 | 05:47 AM
z350boy's Avatar
z350boy
If you want a complete kit check this link:
www.kptechnologies.com
Old Jan 8, 2008 | 07:40 AM
TayTaythatsme04's Avatar
TayTaythatsme04
^^^ Yup, check out KPs starter kit and there is also a thread on using a S2000 starter.
T
Old Jan 12, 2008 | 02:31 PM
KPierson's Avatar
KPierson
The release of the KPtechnologies kit has been delayed a little so we can add a new feature.
Basically, when our kit is done, you'll be able to press and release the button and the module will start the car for you, just like OEM.
No other kit available has this feature.
Old Jan 12, 2008 | 08:17 PM
iknowitsfast's Avatar
iknowitsfast
I'd be interested in this, let us know when there is more info!
Old Jan 12, 2008 | 08:22 PM
Spork's Avatar
Spork
I want this push-start button! More gadgets to make the people go "ooh" and "aah".
And a sportier feel IMO
Old Jan 12, 2008 | 08:34 PM
TheBlackPearlZ's Avatar
TheBlackPearlZ
yeah ive been waiting patiently for KP to finish up...i want to be one of the first to get one
Old Jan 13, 2008 | 11:27 AM
merlin3's Avatar
merlin3
Kevin could easily release it now as I've seen it in action but knowing kevin he'll wait till it is perfect before releasing it so you guys will be in for a treat when it's done.
Old Jan 13, 2008 | 01:24 PM
kspec's Avatar
kspec
o0ooo keep the key in our pocket or something?
Old Jan 13, 2008 | 02:59 PM
KPierson's Avatar
KPierson
No, the key will still need to be in the ignition to unlock the steering wheel and satisfy the requirements of the Nissan transponder security system.
This version of the module is completely unintrusive to the OEM security features.
But, like I said, once it's done you'll be able to simply press and release the button, instead of holding the button down for the duration of the 'crank' part of starting the car.
Old Jan 14, 2008 | 03:05 PM
TurboTrey's Avatar
TurboTrey
What is the point of a push button start if you have to put the key in? Wouldn't you still have to stick the key in and turn it half way? Why not turn your wrist 10 degrees more and start it.
Old Jan 14, 2008 | 03:28 PM
KPierson's Avatar
KPierson
It's just another gadget.
Whenever I have someone in my car and I pushbutton start it they always comment on it. It draws a lot of attention, most likely because it is still somewhat new and not many people have seen them in OEM form.
It isn't a convenience thing at all, it's more of a 'look at what I have' thing.
Old Jan 14, 2008 | 04:43 PM
kspec's Avatar
kspec
yea its just another neat toy.
i like it!
Old Jan 14, 2008 | 05:50 PM
sintaxeror's Avatar
sintaxeror
Where would we install it?
Old Jan 16, 2008 | 06:14 PM
KPierson's Avatar
KPierson
Mine is installed where my cigarette lighter was, but I drive a G35. It is really up to personal preference and wherever there is room.
Old Jan 17, 2008 | 12:36 PM
Da K00l Aid Man
So KP, is there any expected date when the new module will be ready ?
Old Jan 17, 2008 | 01:19 PM
KPierson's Avatar
KPierson
As soon as possible. The new feature required quite a bit of modification to the original design, so its taking a bit longer then I expected. I had to add an entire routine to monitor and program a tach signal for the unit to monitor so that it knows when to shut the starter off.
As of right now I have all the code done for the programming part, now I just have to finish the actual starting side of it.
Old Jan 17, 2008 | 05:07 PM
davidz33's Avatar
davidz33
Not to steal this thread, but here I go anyway
KP,
Here's an idea in addition to the push button...
I always wanted a passcode type of starter system. I think I saw this in the movie transporter 1. Basically, a driver punches a passcode to the numberpad somewhere in the car to start.
Of course our key will need to be inserted and turned to unlock the steering wheel lock, but but somehow disable to start using just the key for security purpose. If done right, I think this will be a good security feature not just for coolness factor.
Is this a feasible idea?
Old Jan 17, 2008 | 05:47 PM
merlin3's Avatar
merlin3
viper already makes a keypad add on like this. My 300zx had one when I bought it and I quickly got rid of it as it was retarded. I guess I could see if you were in a high crime area. Also most of them are pretty easy to bypass.
