Should I replace bose system?
Old Jan 30, 2008 | 07:07 AM
mk3vento96's Avatar
mk3vento96
Default Should I replace bose system?
my driver side speaker keeeps cuting in and out sometimes as well as the sub. Its very annoying and just starting to get to me. I know Bose is suppose to be very good. But i was wondering weather i should replace the system with a aftermarket system (JL) or just buy all new stock bose speakers...feedback is needed, thanks
Old Jan 30, 2008 | 07:10 AM
NickRaine78's Avatar
NickRaine78
Plain and simple....its teh suk replace!
Old Jan 30, 2008 | 07:21 AM
VO...'s Avatar
VO...
Administrator
Yes, replace....
Old Jan 30, 2008 | 07:23 AM
StreetOC192's Avatar
StreetOC192
Originally Posted by vo7848
Yes, replace....
+1
Old Jan 30, 2008 | 08:04 AM
clarkemtp's Avatar
clarkemtp
Yes. But ONLY if you like music.
Old Jan 30, 2008 | 10:20 AM
Doba's Avatar
Doba
Personally I like the sound of the stock Bose system, its all I need, I’m done with the 1000 watt systems that make me go def.
so really its all in your preference
Old Jan 30, 2008 | 10:50 AM
zeekle's Avatar
zeekle
well I doubt its your speakers that are causing the problems. It is most likely the amp and if its not covered under warranty you could get a nice start on a new system for what it would cost to replace that.
Regardless of sound quality of the bose system I would look to replace it if it was giving me problems like you describe.
I am not sure how much you are going to have to spend to get a better sound than that of the bose system.
Old Jan 30, 2008 | 11:32 AM
Da K00l Aid Man's Avatar
Da K00l Aid Man
my main issue with my Bose system is that the CD player skips every CD I put into it, even brand new ones.
Old Jan 30, 2008 | 12:18 PM
mk3vento96's Avatar
mk3vento96
mine too!! so annoying..
but thanks for the feedback guys, well guess i will replace it then...
JL audio here i come
Old Jan 30, 2008 | 04:39 PM
dragon11689's Avatar
dragon11689
I wonder if one of those radio shack cd cleaner discs with the brushes on them to clean the lens will work to fix the problem? Any ideas or past experiences with that guys?
Old Jan 30, 2008 | 09:27 PM
Spike100's Avatar
Spike100
^^ Anyone using a CD/DVD player as primary AV is a target for stuff like this. They figure that if you are using old technology, you’re likely to “bite”
Do not be a “victim.”
--Spike
Old Jan 31, 2008 | 02:36 PM
dhwang80's Avatar
dhwang80
i'm sure the bose is not ideal for music with tons of bass. But i enjoy it and I think it sounds pretty nice for stuff I listen to.
Old Jan 31, 2008 | 03:24 PM
Spork's Avatar
Spork
If you care about good sound and being happy with the music quality, change out all the BOSE shat.
Old Jan 31, 2008 | 08:07 PM
dragon11689
So there is no real way to get rid of the skipping or fading if you want to keep your bose system?
Old Jan 31, 2008 | 08:20 PM
Spike100's Avatar
Spike100
^^ If you still under warranty, take it to your Nissan dealer for a repair/swap.
If you are past warranty, pull all of it and install a decent CES.
Bose makes good components, but the better components from Bose are not inside your Z.
--Spike
Old Feb 1, 2008 | 06:55 PM
dragon11689
Are there decent head units I can put in and still use with factory speakers and sub?
sales@czp
Sep 23, 2019 03:30 PM
350z82
Oct 1, 2015 06:25 PM
