stoping the ratling
Old Feb 5, 2008 | 01:21 PM
D'sNuts's Avatar
D'sNuts
Default stoping the ratling
trying to see what the best way would be to get rid of the insane rattle i get from the back hatch area when my subs are bumping.. seems to be the hatch itself and the outer rim of the cargo area... what have you all done to fix the rattle to make your z rattle free?
Old Feb 5, 2008 | 01:27 PM
Lsmith9523's Avatar
Lsmith9523
I would deff. recommend some type of sound dead material. IE: Dynamat, Edead, there are lots of different types. I personally used Rammatt. Also, make sure you use the Ensolyte foam as well. Trying doing a search on some of the brands listed above. There are several threads here listing different brands, how-to's and photos. I hope this helps.
Old Feb 5, 2008 | 08:51 PM
Mr.'s Avatar
Mr.
Fire the subs towards the cabin? Dynamat can only do so much.
Old Feb 5, 2008 | 10:43 PM
D'sNuts's Avatar
D'sNuts
ok thanks will try the dynamat route see how it turns out
Old Feb 6, 2008 | 03:47 AM
Lsmith9523's Avatar
Lsmith9523
With the Zenclosure you cannot fire the subs towards the cabin. So, given the enclosure and direction the bass is being directed,,,I would use a type of sound dead material. I am only speaking from experience. I had the same issue. I installed my zenclosure, dual 10's. I only Rammatt'ed the hatch floor, sides. I experienced the same "said" rattle,,I then removed the upper hatch panel,,used some Rammatt and ensolyte on the upper panels,,,,the vibration has @95% vanished. Although,,a lot of that would depend on how much power you are feeding the subs, volumn level, ect. ect. Just my opinion and experience.
Old Feb 6, 2008 | 06:52 AM
SChetal's Avatar
SChetal
From exp. I can tell you most of the rattling comes from the actual hatch, just remove the panels and apply some deadning and automotive carpet, the problem should be gone...(make sure to remove, rear wiper motor and deaden behind it)
Old Feb 6, 2008 | 12:01 PM
D'sNuts's Avatar
D'sNuts
awesome im going to get right on it thanks guys
Old Feb 6, 2008 | 12:02 PM
350zspl's Avatar
350zspl
there are many different brands of sound deadning material
spray
peel and roll
foil back
black back
shop carefully
Old Feb 6, 2008 | 12:48 PM
D'sNuts's Avatar
D'sNuts
another question while this thread is active.. why is it that when you open the hatch when the subs are bumpin that the bass diminishes where as when the hatch is closed the bass is there and soundin good, my friend told me the sound waves need something to reflect off of, when i let me subs hit while the hatch is open it doesnt sounds to pretty.. im sure theres as a very simple and logical explination but when i installed the subs i was under the impression that i would be able to show people how they sound with the hatch open.
Old Feb 6, 2008 | 02:19 PM
clarkemtp's Avatar
clarkemtp
Google is your friend. Try looking up the terms "cabin gain" and "transfer function" as they relate to car audio. You'll learn all you wanted to know and then some about the question you're asking.
Old Feb 6, 2008 | 06:27 PM
D'sNuts's Avatar
D'sNuts
awesome thanks
bigmikewhite6
Apr 5, 2007 10:52 AM
autois4pussies
Aug 6, 2005 11:24 PM
neonsinn2000
Jul 13, 2005 08:58 AM
350zRat
Jun 27, 2004 11:45 AM
LBSOHK
Jul 15, 2003 07:12 PM
