Where should I ground my amp which is in the glovebox?
Old May 2, 2008 | 09:59 AM
nyguy4u's Avatar
nyguy4u
There isn't a good ground anywhere near the fuse box location? I need to jump over to the center console?
Old May 2, 2008 | 11:09 AM
doug's Avatar
doug
i'm sure there is.. i just havn't used one so i can't recommend it.. any bare metal should be a good ground.. thats why i suggested a volt meter.. that way you can actually see what is giving you good ground.. or if you have to grind/sand it down
Old May 2, 2008 | 11:52 PM
ZDRERUN's Avatar
ZDRERUN
Originally Posted by smaha
my rule is find the thickest metal, closest to the amp then grind down to bare metal. the shorter the ground lead, the better. if you can get to chassis to ground, that would be the best.
this is what works best for a good strong ground
(try to paint over it to prevent rust on the spot you grind if its a small connection you can even use nail polish)
m_0g
Jun 3, 2021 10:05 AM
hulkout
Tuning
Sep 30, 2015 12:33 PM
OdesiTT
Sep 30, 2015 10:47 AM
cashmoney03
Sep 27, 2015 05:24 PM
Shane86
Sep 17, 2015 05:33 PM
