Avic D3 install question...
Old Mar 12, 2008 | 07:42 AM
lukep90's Avatar
lukep90
Smile Avic D3 install question...
hey, i asked this in another thread, but it never was responded to so...
when installing the D3, where is the best place to drill for the ipod cable to come through? ( i take it everyone runs it through the top cubby? is there any way to make it look clean and not have a big hole for it to fall through???
anyone have it come through the compartment below their elbows?(that little box)
and finally, are there any installation differences between the 2004 and the 2006??? (disassembly maybe?)
thanks to all!
Old Mar 12, 2008 | 09:42 AM
Project3fiftyZ's Avatar
Project3fiftyZ
I would be curious to know this too. My dash kit should be here any day now and then I will be tearing down the dash to install. I am going to look at some of the previous installs by Bing and see if he shows a clean install of iPod cable. If I find one I will post it here and let you know.
Old Mar 12, 2008 | 01:21 PM
Spork's Avatar
Spork
With my old Kenwood DDX6019, I ran the ipod connector through the center console to the small rear cubby behind the driver seat. Worked perfect.
Old Mar 12, 2008 | 07:03 PM
lukep90's Avatar
lukep90
how hard is it to thread it through the elbow glove box? (for lack of a better name...) what would i do to get to it???
thanks!
Old Mar 12, 2008 | 07:57 PM
lukep90's Avatar
lukep90
I found it, https://my350z.com/forum/showthread....t=avic+d3+ipod
thanks, i think im going to install it in the back cubby behind the drivers seat
Old Mar 13, 2008 | 08:54 AM
GeauxLadyZ's Avatar
GeauxLadyZ
Default Why??
why in gods name would you put it behind the drivers seat?? Out the coin box (under your elbos) is a much better place, or even out the cup holder compartment (03-05) if worry about the hole just use a rubber wireharness threadthrough plug ( for lack of real name) like the ones for the cars wires wireharness going through the door-to-body and on the firewall (engine-to-pass compartment).
Old Mar 13, 2008 | 08:58 AM
cheshirecat79's Avatar
cheshirecat79
In regard to the "making a hole small enough for it to fall though", cut the hole large enough to feed the avic connector through. It's kinda square and you can bend it in there with a circular hole. The ipod connecter is thin and wide, and will not fall in.
You can also use a rubber grommet if you just cut it to size.
Old Mar 13, 2008 | 06:42 PM
lukep90's Avatar
lukep90
thanks for the help. i actually put it into the elbow glove box. (easier acess)
another question. Does anyone have any pictures of the back of their AC control unit for the 350z>? i cant manage to disconnect it from the wires behind it for my install. i feel three distinct wires, but have no idea what to do do disconnect the bloody thing.
any help is much appreciated!
Old Mar 13, 2008 | 07:58 PM
lukep90's Avatar
lukep90
any tips???
Old Mar 14, 2008 | 06:05 AM
GeauxLadyZ's Avatar
GeauxLadyZ
Default snap plug?
its not just a snap-plug like the speakers/power-harness that snaps in the back of your H/U?? I would think you should just have to press down on little clamp while at the same time you pull out. Most dash wire harnesses use these snap-plugs for easy take-out.
Old Mar 14, 2008 | 06:18 AM
cheshirecat79
Yep, just use a small screwdriver to push the top clips down and work the plugs out. Some may be a little tight so you'll have to wiggle them a bit while you hold down those clips.
zfetish
Jul 4, 2006 01:20 PM
farber
May 23, 2006 07:47 AM
SteveZ33
May 19, 2005 08:43 AM
SteveZ33
Apr 27, 2005 08:56 PM
