PLEASE HELP!!! Navigation cable
Old Mar 16, 2008 | 07:37 PM
davidc81's Avatar
davidc81
Question PLEASE HELP!!! Navigation cable
the wire that attaches the motorized cubby lid to the main harness was cut. does anyone know what type of wire it is, where i can get a replacement, or if i can get it repaired? is there a part number for it? i went to nissan and they said i have to get the whole harness for the whole car replaced which is $1200. i've attached some pictures for reference.
Old Mar 19, 2008 | 12:59 PM
davidc81's Avatar
davidc81
does anyone know where i can order this? i've been searching with the words printed on the cable and it seems they used this type of wire in printers
Old Mar 26, 2008 | 07:40 AM
davidc81's Avatar
davidc81
anyone have a spare they would sell me???
Old Mar 28, 2008 | 01:32 PM
jhagan's Avatar
jhagan
Better hit the junk yard.. I'm sure some poor sole wrapped his Z around a tree in your area..One man's junk is another man's fortune.
Old Dec 16, 2008 | 07:31 AM
davidc81's Avatar
davidc81
Vendors- Can any of you get me this cable???
Old Dec 17, 2008 | 09:17 AM
burner's Avatar
burner
I wish I could give you a cable....but I can't. But, if you are decent with a soldering iron (or know someone who is) you can probably fix this. It wont look pretty, but its possible. I've done it before on a ribbon cable just like this. Get an Exacto knife and strip away the cover from each of the contacts. Get some really thin wire (maybe 20ga for this) and cut however many pieces you'll need. Pull the other end out of the connector and start soldering. You have to be careful becasue you can't cross any of the contacts. You could use the knife to slice each wire in the ribbon it it has its own section, which would make things easier. I know this isn't the idea solution, but if you can't find the harness it may be all you have!
Old Dec 18, 2008 | 10:44 AM
davidc81's Avatar
davidc81
unfortunately i no longer have the cable. i lost it when i moved. anyone know where i can get this cable?
Old Apr 27, 2009 | 09:08 AM
davidc81's Avatar
davidc81
bump
Old Apr 27, 2009 | 11:19 AM
xNeo's Avatar
xNeo
Your best best is going to a junk yard, if it's part of the harness you can't just buy it. Chances are they used this on other cars not just the Z. You can easily repair it, or hack something to get it to work. Go to a local car audio shop they might be able to fix it for you.
Old Jan 8, 2010 | 11:33 AM
davidc81's Avatar
davidc81
bump. someone please help!
Old Jan 8, 2010 | 04:37 PM
Spike100's Avatar
Spike100
^^ Wow! Almost two years later and you still need this part (which probably is worth less than $20).
It appears to be a standard ribbon. You need to know the pin-outs. This information is available in Nissan's service manuals.
Did you contact Nissan and ask for this information?
--Spike
Old Jan 9, 2010 | 05:10 PM
davidc81's Avatar
davidc81
i went to the dealer and they told me i would have to buy a complete wiring harness which is $1200. they wont sell me just this one part.
Old Jan 9, 2010 | 05:16 PM
Spike100's Avatar
Spike100
Originally Posted by bigaudiofanatic
No they can not be repaired you need to buy a new one. Go to your dealer.
You can repair the ribbon/wire. ...not easy. but possible. Of course you need the wiring diagram.
--Spike
Old Jan 11, 2010 | 11:48 AM
JasonZ-YA's Avatar
JasonZ-YA
one weekend going to a few junk yards and you can find this.......
jebus man...2 years.........hit up a junk yard dude...youll find it...
-J
Old Jan 11, 2010 | 12:09 PM
davidc81's Avatar
davidc81
-J
trust me man i've tried! not too many z's with navigation and even less wrecked z's with navigation
Old Jan 11, 2010 | 12:12 PM
JasonZ-YA's Avatar
JasonZ-YA
okay, ill look for it the next time i go...........i know of a junk yard that had two z's with nav....ill check to see if those two z's are still there..
pm me your cell..........this will be one of those, "im going now, ill call you when im there sorta deals"........
when im at the counter ill call you and ensure you want it at whatever price the burly, low self-esteem Junk yard owners want for it...
-J
2ndchanceZ
Oct 26, 2015 08:03 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
Tochigi_236
Sep 27, 2015 03:40 PM
hulkout
Tuning
Sep 18, 2015 05:42 AM
