Pioneer AVH-P4000DVD?
Old May 23, 2008 | 07:48 PM
  #41
unr's Avatar
unr
ok guys i just got the this head unit installed at meyer emco and everything works perfect except the stock navigations voice doesn't come out of the speakers any suggestions on how to fix this problem. thankx will post pics soon aswell.
Old May 23, 2008 | 07:50 PM
  #42
lionheartednyhc's Avatar
lionheartednyhc
Glad it works! I dont think you can get the navi voice to work I hate that voice, its so damn annoying so it never bothered me.
Old May 23, 2008 | 07:58 PM
  #43
unr's Avatar
unr
i don't mind for the voice either, but i like to know i can have it if i want it. I am kinda weird about stuff like that. Are you sure there is no way to make it work though?
Old May 23, 2008 | 07:59 PM
  #44
lionheartednyhc
From what I understand, it only works w/ the stock HU..maybe someone else knows more...
Old May 23, 2008 | 08:04 PM
  #45
unr's Avatar
unr
damn oh well thanks anyway. If you find anything out let me know please
Old May 26, 2008 | 06:03 AM
  #46
IndyZ-man's Avatar
IndyZ-man
The stock head unit is the only one that can integrate the voice into the system. However, you can install a small speaker wherever you choose (under driver's seat, behind driver's seat, under front dash, etc) to hear the voice. It has to be a stand alone speaker seperate from the main system.
Old May 26, 2008 | 11:14 PM
  #47
stanleylee's Avatar
stanleylee
hello guy i have a 03 z with bose system( no navi ), do i need to buy any extra part to install the HU other then that dash kit ? something like PAC whatever it is ?
Old May 27, 2008 | 04:52 AM
  #48
IndyZ-man's Avatar
IndyZ-man
You should still need to buy a wiring harness kit to hook into the stock system. Unless you want to hack up the oem wires. Not recommended!
Old May 27, 2008 | 01:09 PM
  #49
stanleylee's Avatar
stanleylee
which mean i need one of these in order to fit the after market H/U to stock system?
http://www.sonicelectronix.com/item_...ROEM-NIS2.html
Old May 27, 2008 | 04:17 PM
  #50
Spike100's Avatar
Spike100
I haven’t done this with the Z’s OEM Clarion stock navigation, but I have connected an aftermarket “standalone” navigation device to an aftermarket H/U that does not support a mute feature. I also did this with the Z's stock Clarion H/U (but did not try this with the OEM Bose system). I was able to route the navigation voice commands thru the Z’s front speakers.
I used a PAC Audio Source Switcher (mutes radio when sending navigation voice commands to the front or rear speakers)
Here is the ".pdf" on the device:
http://www.pac-audio.com/instructions/as21.pdf
For this to work, you need to locate the audio-out terminals on the Z’s stock navigation device, and connect these to the PAC Audio Source Switcher. You also connect the aftermarket H/U audio outputs to the inputs on PAC device. Then, output the PAC device (either to an external amp if you have that, or directly to the speakers).
--Spike
Old May 27, 2008 | 06:42 PM
  #51
IndyZ-man's Avatar
IndyZ-man
As for replacing the stock H/U with an aftermarket one, you would need (for example, the metra 70-7550 & 70-7551.) There are other harness kits available, but all you need is the harness to plug into the factory wiring and then you splice it together with the aftermarket unit. The second one integrates the oem amplifiers. I'm not familiar with the PAC unit you have linked here and it says it only works up to 2002 models. I'm also not a stereo guru either. Hope this helps.
Old May 30, 2008 | 11:05 PM
  #52
getsomez's's Avatar
getsomez's
I've found that Metra parts are kinda hit or miss. I've used parts from BEST and haven't had near the fit and finish problems I've had with others like Metra, scosche, etc. Go to www.bestkits.com and put in your vehicle model and year. They will tell you the exact parts you need.
Old Jun 5, 2008 | 09:43 PM
  #53
IndyZ-man's Avatar
IndyZ-man
Originally Posted by lionheartednyhc
Ok, so I got the 4000 installed today along with some goodies (BT, Sirius, and a BOYO backup camera). Its basically the exact same thing as the Avic, without the navigation and half the price! (and sadly, I dont think you can upload custom backgrounds either ) Interface is awesome, just like the AVIC! I love it. Works perfectly with a Z, everything hooks up, no problems. Only problem I experianced is the fact they my a/c doesnt work. ****ing installer messed it up. Hope its not hot until tuesday... Oh, and of course I got the ebrake bypass too Here it is:
Can anyone tell me exactly how the ebrake bypass is done on this unit? My shop intalled everything, but said that a switch is needed to fool the HU into thinking the ebrake is on. Do I really need to toggle a switch for this? Thanks in advance!
Old Jun 6, 2008 | 08:38 AM
  #54
lionheartednyhc
I dont know exactly how its done, i suck at electronics. Originally I had a toggle switch installed, but it was a PITA to have to toggle it everytime I turned the car in. A diff shop ended up installing a pulse thing that automatically fools the HU everytime the car turns on. Hope that helps...
Old Jun 6, 2008 | 12:15 PM
  #55
Lsmith9523's Avatar
Lsmith9523
I have the PAC TR-7 installed on my Alpine W-200. It takes care of all pulse signals. It comes with instructions on how to install/wire,,,,ect. ect. I used the toggle switch thing for awhile,,,but became a pain.....
Old Jun 8, 2008 | 05:35 PM
  #56
Brutal_LS1's Avatar
Brutal_LS1
search ebay for 'pioneer bypass' and you'll see the pioneer black box bypass for like 30 bucks. one wire to the power, two grounds, one to the blue and white remote wire, and one wire to the green wire off the headunit and you're golden. works perfectly and you never have to mess with it!
Old Jun 9, 2008 | 03:00 AM
  #57
Lsmith9523's Avatar
Lsmith9523
Oh, by the way I think someone said the metra kit was diff for 06 vs 07+...but 06-08 take the same kit. Just FYI. Good luck on your install!
03-05 Metra dash kit 99-7402
06 and up Metra dash kit 99-7602
Old Jun 9, 2008 | 01:24 PM
  #58
enlite's Avatar
enlite
I have a 2005 350Z, and I just bought the Pioneer AVH-P4000DVD and Crutchfield sent me the 03-05 Metra dash kit 99-7402.
Should I return it for the 06 and up Metra dash kit 99-7602 ?
Old Jun 9, 2008 | 01:26 PM
  #59
lionheartednyhc
Um. You have a 2005 car...
you need a 2005 dash kit.
math ftw
Old Jun 9, 2008 | 01:37 PM
  #60
enlite's Avatar
enlite
I was just wondering if the newer kit would look nicer..
math ftw
