critique (not flame) my new system choices!
Old Mar 29, 2008 | 12:00 PM
lukep90's Avatar
lukep90
Default critique (not flame) my new system choices!
i had a set of focal polyglass speakers in my brothers car for a while, but the tweeters are just too damn harsh.
anyways, i am plannin on ordering this setup in the next few days for mine. lemme know what you think, and if it will work well together...
Comps: dls UP6
Amp for comps: ED nine.2
Sub: Image Dynamics IDQ10V3 (4 ohm? or 2, not sure...)
Sub Amp: ED nine.2 (i can bridge that, cant i?)
30 sq ft of ED's light sound deadening material for the doors.
thats about the extent of my budget... (works out perfectly actually)
im in the process of making a sub box (similar to syntaxerror's) and will have both amps in the drivers side cubby.
thanks a ton!!!
Old Mar 29, 2008 | 12:04 PM
Kwame's Avatar
Kwame
Headunit?
Old Mar 29, 2008 | 01:33 PM
lukep90's Avatar
lukep90
avic d3 (already installed)
Old Mar 29, 2008 | 02:42 PM
350zspl's Avatar
350zspl
looks like fine choices to me
Old Mar 29, 2008 | 03:53 PM
16psibrick's Avatar
16psibrick
Simplicity in Sound
not bad, again, on the up6, as any other pseaker, my opinion is still if you put it in stock locations, they wont generate much midbass and the highs maybe a bit forward
b
Old Mar 29, 2008 | 03:54 PM
16psibrick's Avatar
16psibrick
Simplicity in Sound
oh and oy uneed the dual 2ohm to make it 4ohm for hte nine.2
b
Old Mar 29, 2008 | 04:01 PM
lukep90's Avatar
lukep90
b
This one???
http://www.woofersetc.com/index.cfm?...roduct_ID=5806
hows that compare to a FI Q10??? (kinda still between the two..)
thanks to all!
Old Mar 29, 2008 | 05:11 PM
sintaxeror's Avatar
sintaxeror
Sounds good to me.. then again its very similar to mine so ofcourse I would like it
Old Mar 29, 2008 | 06:00 PM
16psibrick's Avatar
16psibrick
Simplicity in Sound
its hard to compare the two, both i think would sound good and have similar performance, just pick th eone you like thelooks of better i hae never done an back to back A/B comparison of the subs in the same enviroment, so its very hard to compare, bu ti really do love the way the new IDQ sounds and have a lot of output and i know the IDQ should be much lighter than the FI, with its composite basket
b
Old Mar 29, 2008 | 07:00 PM
cbr900son's Avatar
cbr900son
Sounds like good choices to me.
Old Mar 29, 2008 | 07:02 PM
doug's Avatar
doug
when i saw no flame in the title.. i could have sworn this was a full JL setup
Old Mar 29, 2008 | 08:29 PM
cbr900son's Avatar
cbr900son
lol +1
Old Mar 29, 2008 | 11:53 PM
lukep90's Avatar
lukep90
would another crossover be necessary/helpful in this case???
if so, hows this
http://www.woofersetc.com/index.cfm?...roduct_ID=2756
thanks again!
Old Mar 30, 2008 | 06:28 AM
350zspl's Avatar
350zspl
Originally Posted by lukep90
This one???
thanks to all!
you can run 1k to a q and 500 to the idmax
Old Mar 30, 2008 | 06:31 AM
350zspl's Avatar
350zspl
if so, hows this
thanks again!
personally i just use the amps crossovers and or head units lp and hp
i don't see the need to for this pg eq if you just running 1 10" and a set of front comps , but that is me
sales@czp
Sep 23, 2019 03:30 PM
Justin100
Nov 29, 2015 03:58 PM
nanotech
Oct 2, 2015 05:02 AM
