Quick Head Unit Install Question (Amp?)
Old Apr 1, 2008 | 03:10 PM
BPS2007's Avatar
BPS2007
Default Quick Head Unit Install Question (Amp?)
I know the Bose system has an amp, but I have a 2008 BASE 350z. Although the DIY Avic-D3 guide looks pretty easy, but I'm more comfortable having the pros do it (not a good solderer!). Anyways, I got quoted for the install of the Avic-D3 in my BASE '08 and he said that there is a "small amp" that needs to be wired up, so its going to be a lot more than he first thought.. roughly $250-300 if all goes well... Just wanted to know, do '08 Base models even have an amp? The DIY on here looked pretty damn simple.. I may just DIM if it will save me that much money.
Old Apr 1, 2008 | 03:32 PM
marhot's Avatar
marhot
Go to Audio Video sub-forum
Old Apr 1, 2008 | 03:58 PM
Apanther's Avatar
Apanther
If you are not experienced with installs, I would recommend that you have someone install it for you. If you have installed several decks before, single din units, etc, then you can do it no problem.
Old Apr 1, 2008 | 04:16 PM
BPS2007's Avatar
BPS2007
I'm definitely having a professional do it, but as of right now my installer is under the impression that there is a factor amp that needs to be wired up to the new HU. Is there an amp in the 2008 base or not? This could save me a good chunk of change it seems. Thank you.
Old Apr 1, 2008 | 05:06 PM
Spork's Avatar
Spork
Eh, in my 2003 with BOSE, the BOSE system worked fine and all I had to do was use the wiring harness. I've never had to do any "Amp-Bypass" like people have been saying.
Old Apr 2, 2008 | 10:08 AM
Master Shake's Avatar
Master Shake
Don't Bose systems have a different ohm rating that other OEM or after market systems? I thought I heard there is some sort of conversion system required if you try to change out one part of your Bose system while leaving the rest as is.
Old Apr 2, 2008 | 11:12 AM
boosted99gst's Avatar
boosted99gst
Nobody is answering this guys question.....
All he wants to know is if there is an amplifier in the 08 base model Z? 08 base owners please chime in....
Old Apr 2, 2008 | 05:45 PM
BPS2007's Avatar
BPS2007
Lol, yes, please! I'm sure the 08 didn't change anything from the 07 audio, but my audio guy is under the impression that there might be something different in the 08.
I got off the phone with him a few hours ago, and he sorta explained a few of the things that may pose to be an issue, along with the fact that apparently there's more to it than to just do the e-brake bypass? Apparently Pioneer is the ONLY company that has a built-in switch or something that automatically turns off a DVD at 5mph?? He said this is the case with the avic-d3... is this true??
He also noted the "tiny amp" again.. he said that by hooking everything up right will allow me to build onto my current set up easily and correctly.
It just amazes me that SO many people apparently installed this unit THEMSELVES without a problem, but apparently this guy is telling me that this could be a potentially complicated/costly install... is he correct about the 08's or is he wrong???
Old Apr 2, 2008 | 05:56 PM
lukep90's Avatar
lukep90
if the 08 is in fact the same as the 07, he is dead wrong. i suggest that you read the avic d3 install guide on this forum to get a better understanding. all the bypass entails is splicing a wire and grounding two of them. easy as that.
Old Apr 3, 2008 | 02:15 AM
whitemikecn's Avatar
whitemikecn
I just put a Avic-Z2 in my Nismo which has the same HU and wiring as yours.... No there is not an amp. Also I will note that the guy is raping you! Circuit City will do it for 99 bucks. If you were in Jax, FL I would do it for you for free. It would take you maybe 2 hours to do it urself with no prior expierence.
Chris
m_0g
Jun 3, 2021 10:05 AM
bcoffee20
Nov 19, 2015 06:39 PM
Vigman
Nov 17, 2015 04:34 AM
cashmoney03
Sep 27, 2015 05:24 PM
bryanlam199
Sep 24, 2015 04:04 PM
