Porting a Zenclosure
Old Apr 21, 2008 | 11:45 PM
702Fairlady's Avatar
702Fairlady
Default Porting a Zenclosure
Thinking about getting a single 10" zenclosure box, and putting an fi audio BL series in it. I just think that the ported box is going to get a little lower bass for me. I know that crutchfield sells aero ports for subwoofer boxes for like 5-10 bucks. So If i get a Zenclosure with like 1.0cuft of airspace, what diameter and length pipe should I get?
Old Apr 21, 2008 | 11:48 PM
702Fairlady
And if I dont go with the single 10, I'm also tihnking about getting the dual 12 box Zenclosures sells, porting it, and throwing some Alpine R's in there.
Old Apr 22, 2008 | 03:52 AM
StreetOC192's Avatar
StreetOC192
How so? This isn't always the case (in fact rarely). ported boxes 'seem' to dig deeper because they are easier to get louder at the tuned frequency. The truth is a sealed enclosure of proper volume and fed the proper power can yield deeper bass from a given driver, although not necessarily louder with a given amount of power. You say you want deep, then sealed would be better for you, if you want louder at an optimal '33Hz' or whatever you are tuning the ported box to - and then have a steep rolloff below that, then ported will suit your needs better.
But anyway, you 'could' do it. What Zenclosure has 1 cu ft volume?
These links should help you figure out everything you need:
http://www.subwoofertools.com/forum/ported-box.asp
http://www.carstereo.com/help/Articles.cfm?id=31
Old Apr 22, 2008 | 03:56 AM
phreaktor's Avatar
phreaktor
Design Engineer
The boxes do not have the proper airspace to be ported. You could have one custom made for 1 12", but there is not enough room for two. For example RF P3 12" require 1ft ^3 for sealed. But for a ported box they need 1.75ft^3!
Old Apr 22, 2008 | 11:15 AM
350zspl's Avatar
350zspl
after you port a zenclosure
you will wind up with no internal space
Old Apr 22, 2008 | 11:19 AM
StreetOC192
I had thought about that, but then remembered Mike sells a single 10" understrut box with amp rack that has a gross 1.4 cu ft volume. After port and Fi Q sub are installed, he will probably net a good 1.1 cu ft.
http://cgi.ebay.com/ebaymotors/Nissa...spagenameZWDVW
Old Apr 22, 2008 | 01:29 PM
702Fairlady
So which do you think would be better, the one 10 or the 2 12's. I've never owned a sub smaller than a 12 so im not sure i'll satissfy my bass needs with the 1 10.
Old Apr 22, 2008 | 01:43 PM
Shyn's Avatar
Shyn
1 10" sub given the right amount of power in the proper box SHOULD be able to satisfy anyones need for bass in a Z
Old Apr 22, 2008 | 03:04 PM
702Fairlady
Well I have one kicker 12L7 in there now, and I like the way it sounds. But still wanna get a tad louder and deeper
Old Apr 22, 2008 | 03:05 PM
350zspl's Avatar
350zspl
if a person wants to run a q no REAL reason to port anyway
they do great sealed
but if you wind up with a net cu ft after port it still works
Old Apr 22, 2008 | 03:07 PM
350zspl's Avatar
350zspl
i like 12's and 15's ported
that's just me
no chance you want a custom ported enclosure ?
you want to retain trunk space?
Old Apr 22, 2008 | 03:10 PM
350zspl's Avatar
350zspl
i do like l7 by the way alot
Old Apr 22, 2008 | 03:11 PM
350zspl's Avatar
350zspl
maybe 1 9515 dd 10" off 3k for me anyway
Old Apr 22, 2008 | 03:19 PM
Shyn's Avatar
Shyn
your standards are little higher... just a bit
basshead
Old Apr 22, 2008 | 03:34 PM
350zspl's Avatar
350zspl
^^^ i can't help myself ^^^^
Old Apr 22, 2008 | 04:03 PM
702Fairlady
well i was looking at the 10 just to get some space back, but i never erally haul anything in the Z anyways. So I was looking at this box:
http://cgi.ebay.com/ebaymotors/2003-...6647QQtcZphoto
Then I was just gonna get a razor blade to cut off the carpet, and cut a hole into the box to and slide one of the crutchfield aero ports into it. I was thinking about dropping in 2 alpine R's
Old Apr 22, 2008 | 11:39 PM
StreetOC192
If you don't mind giving up the hatch space, let 350zspl hook you up with a setup. I guarantee he won't disappoint.
Old Apr 23, 2008 | 05:25 AM
350zspl's Avatar
350zspl
those are nice boxes you pasted
if you want a custom, LMK
i would be happy to help
Old Apr 23, 2008 | 05:29 PM
adamtaylorpcb's Avatar
adamtaylorpcb
then get away from kicker
Old Apr 25, 2008 | 01:48 AM
702Fairlady
Doesn't matter anymore Car was traded in
https://my350z.com/forum/showthread....74#post5626874
BEBO'S ZEE
Jun 7, 2016 07:48 AM
hulkout
Tuning
Sep 30, 2015 12:33 PM
