Switches
Old Jul 1, 2008 | 09:29 AM
JasonZ-YA's Avatar
JasonZ-YA
Default Switches
Hi,
Anyone do anything with the blank switches next to their heated seat rocker switches? or the ones to the left of the steering wheel that are not being used??
I found that they are a standard size in tons of nissan's. So today i found these two out of a 1998-2000ish Pathfinder.
TOYOTA ROCKER SWITCH THAT ALSO FITS:
http://www.rallylights.com/hella/swi...ted_rocker.asp - at the bottom of the page. Yep, says Toyo part, but it fits.
THIS PIC IS THE TOYO SWITCH IN AN 05+ XTERRA:
THOUGHT I WOULD SHARE. I have a couple of ideas to use these for.
- Jason
Attached Thumbnails Switches-96517.jpg   Switches-cimg1138a.jpg   Switches-img_4600.jpg   Switches-img_4603.jpg
Old Jul 1, 2008 | 09:36 AM
JasonZ-YA's Avatar
JasonZ-YA
I plan on "stealthing" these switches out! you can easily sand them down with some 400 grit sand paper and then spray paint them again.
see these pics from the Xterra forum. I have an 08 X also.
STEP1:
1st pic - Is midway sanded down. Need to keep sanding.
STEP2:
2nd pic - Paint process
STEP3:
3rd pic - INSTALL.
credit to the find: www.thenewx.org member: TRAXTAR3
- J
Attached Thumbnails Switches-step1.jpg   Switches-step2.jpg   Switches-step3.jpg
Old Jul 1, 2008 | 11:46 AM
StreetOC192's Avatar
StreetOC192
You can also get custom with these:
http://www.4x4mods.com/Product/Jeep/...rswitch40.html
Old Jul 2, 2008 | 09:45 AM
JasonZ-YA's Avatar
JasonZ-YA
In case anyone goes to a local junk yard to get switches from pathfinders or the like. FSM can be found here. www.phatg20.com
http://www.phatg20.net/component/opt...,select/id,31/
http://www.nicoclub.com/FSM/pathfinder/1997_Pathfinder/
parent: http://www.nicoclub.com/FSM/
I found what i was looking for...
1st pic is general how to read wiring diagram page:
- J
Old Jul 7, 2008 | 12:07 PM
JasonZ-YA's Avatar
JasonZ-YA
here is the finish product in my Xterra.... you can see the slots/blanks for our Z are the same.
from the wire diagram you can see i have continuity over connection points 1 and 2 labeled under "POWER"
wire #1 - red/white
wire #2 - white/black
the others will take some work since they are AUTO power and not a simple on off switch.......so i didn't care for that... i just hooked up wires 1 and 2 and capped and stowed the rest of the wires.
plan on doing the Z next.... stay tuned...
-j
Old Jul 23, 2008 | 03:45 PM
NCPG's Avatar
NCPG
Great Thread Jason.
I plan to use the blank switch next to the heated seat rocker switches to power my Garmin GVN 53 and in-dash Fahrenheit screen. I'd like to use a lighted rocker switch.
Old Jul 23, 2008 | 06:35 PM
Mikey-Z's Avatar
Mikey-Z
Subwoofer gain control, monitor pwr, carpc pwr.
Old Jul 24, 2008 | 03:24 PM
JasonZ-YA's Avatar
JasonZ-YA
all finished...i finally got around to using the other switch in the Z....
its for my xbox power on and off - for the power inverter.
https://my350z.com/forum/audio-build...avigation.html
- J
Workshop12
Mar 23, 2020 01:45 PM
Beater350z
Sep 9, 2015 03:36 PM
AP350z223
Sep 8, 2015 04:38 PM
