Sound Deadening
Old Jul 30, 2008 | 07:58 PM
Roper215's Avatar
Roper215
Default Sound Deadening
I tried looking for a fairly comprehensive walkthrough on installing sound deadening.
From what I understand a sound deadener will keep sound inside of the car (reflective aluminum and give some vibration reduction).
A mass loader is installed in high vibration areas? Door panel, floor board, and other areas...
Edead (liquid?) is pretty much applied Jack Pollack style and I am unsure as to what the product actually delivers.
I am looking for a when/where/in what order/how many layers, etc. type thing and pics would be greatly appreciated.
Thanks, I am getting my flame suit ready just in case...
Old Jul 30, 2008 | 08:04 PM
Diesel350's Avatar
Diesel350
I would do a 3 step approach to get the best results.
Sound Deadener first, mat or liquid, then a closed cell foam, then a open cell foam. I would install this on the floorboards, trunk, cubby holes, and doors.
Old Jul 30, 2008 | 08:07 PM
Roper215's Avatar
Roper215
Default pics?
You got any pics of the process, I sorta want to see how things are supposed to look at the different stages.
Old Jul 30, 2008 | 08:13 PM
Diesel350's Avatar
Diesel350
Do a search for sound deadening. There are several great threads with pics detailing the install.
Old Jul 30, 2008 | 08:20 PM
Ichigo's Avatar
Ichigo
I have a few of my door
Start at the top and attach your deadener
Be mindful of the holes that are used to attach the door panel, if you cover them, you must poke holes after you place your piece.
Work your way down using a roller.
It will take some time to work around the cables, but if your utility knife is sharp and you have a few extra blades, you'll be done in no time.
I did mine on a nice hot day and I laid out the deadener in strips to prep it for install, once the sun warms it a bit it's easier to work with. Your back will be killing you after just a door so break up the install over a few days. Doors and trunk area can be done at separate times. If you want to go buck nutty and do the floor I would take out the seats remove the carpet, and do from the firewall to the area behind your seats in one shot. You dont want to remove interior pieces more than necessary.
Old Jul 31, 2008 | 04:41 AM
Roper215's Avatar
Roper215
Default Thanks
Cool, I already installed that material on the door surfaces.
I am having issues with vibration on the interior door panel... also, should I use the liquid in the hatch/trunk area and then cover with edead or vice versa? Also, when you install a mass loader, do you install sound deadener on top, sort of like a sandwich?
Old Jul 31, 2008 | 04:56 AM
cbr900son's Avatar
cbr900son
I guess we should get a soud deaden sticky started soon. Tho i must admit i know abit but not the best to probably do this.
Old Jul 31, 2008 | 05:03 AM
Roper215's Avatar
Roper215
Default Previous/Current Threads
I searched around and I couldn't find anything that I was looking for in a timely fashion...
I figured that with some of the installs I have seen on here there could be some light shed on this topic...
Old Jul 31, 2008 | 05:09 AM
Diesel350's Avatar
Diesel350
Here:
https://my350z.com/forum/audio-video...-deadener.html
and here:
https://my350z.com/forum/audio-video...materials.html
Obadabot
Jun 18, 2023 11:31 PM
wanderingstuden
Jan 28, 2016 07:03 PM
Justin100
Nov 29, 2015 03:58 PM
samansharif
Sep 25, 2015 12:31 PM
