Do I Need Spacers????????
Old Sep 9, 2008 | 08:37 PM
engine350zr's Avatar
engine350zr
Question Do I Need Spacers????????
Im gonna be installing a set of Boston Acoustics Pro series 6.5's in the doors and im wondering if i'm gonna need spacers to clear the window? The mounting depth is 2 3/8", any help would be greatly appreciated.
Old Sep 9, 2008 | 10:37 PM
adamtaylorpcb's Avatar
adamtaylorpcb
yes, anything over like an inch needs spacers
Old Sep 9, 2008 | 11:53 PM
16psibrick's Avatar
16psibrick
Simplicity in Sound
yes you will, the pro is by no means a small speaker, and will require a spacer. its not just hte depths, but also the size and shape of hte basket and magnet behind the speaker. for example, a speaker with a neodydium magnet and small bakest such as DLS ultimates, can fit with almost no specer or a very small spacer, where as a speaker with a larger magnet, needs a bigger spacer even though technically the first spekaer is deeper.
but pros, you will need spacers for sure
b
Old Sep 10, 2008 | 04:22 AM
KManZ's Avatar
KManZ
If the baskets are wide, as Bing indicates, I would use the stock speaker spacer method. The speakers I was trying to mount wouldn't work in the ZEnclosure MDF spacers because the speaker's baskets were too wide. But with the stock spacer, I just had to trim out some plastic pieces, and the new speakers fit great.
Old Sep 11, 2008 | 11:24 AM
engine350zr
thanks guys, i think im gonna go another direction and mount the pro's behind the seats and get some Morel Tempo coax's for the doors. But if i were to need spacers where is a good place to get em??
Old Sep 11, 2008 | 03:07 PM
KManZ's Avatar
KManZ
Clicky: ZEnclosures 1" speaker spacer
Old Sep 12, 2008 | 01:48 PM
engine350zr
Thanks again KMan, one last thing though. If i put my Boston Pro's in the rear spaces behind the seats, will i need any special pieces ie; spacers hardware ...etc
? I'm trying to get all my parts and pieces before i tear the whole car apart ( i want to do it just once) know what i mean.
Old Sep 12, 2008 | 02:28 PM
KManZ's Avatar
KManZ
I have no idea about the rears, as I have never replaced them. I wouldn't though, save your money and just concentrate on the fronts, as most people here will suggest. I have my rears completely turned off.
Old Sep 19, 2008 | 11:19 PM
chrisl113's Avatar
chrisl113
i have a question when you add spacers to the stock door hole does the stock grill fit over the front of the speakers? thanks
Old Sep 20, 2008 | 09:53 AM
chrisl113's Avatar
chrisl113
also for you all that seem like you know i was curious if ill need spacers for these?http://www.infinitysystems.com/car/p...=US&Region=USA
also will these drop in ok in the back locations?http://www.infinitysystems.com/car/p...=US&Region=USA thanks!
Old Sep 20, 2008 | 04:44 PM
adamtaylorpcb
get better fronts and forget the back stage
Old Sep 20, 2008 | 06:19 PM
Spork's Avatar
Spork
You do not need any other hardware.
You'll be surprised how easily the new speakers will bolt right in using the stock bolts.
Old Sep 20, 2008 | 10:20 PM
chrisl113's Avatar
chrisl113
better fronts? im on a budget and can get these $107 n.i.b., and with 93 db sensitivity can you suggest anything "better"? plus i was asking if i would anything to bolt these in the stock locations? thanks
Old Sep 21, 2008 | 05:15 AM
matix101vz's Avatar
matix101vz
make your own ... i used the stock spacers and cut the middle part out and mounted the new speakers to it and it works better then aftermarket. ... theres a DIY somewhere for it maybe on the wiki
FromGtoZ
Sep 20, 2015 03:41 PM
torchkc
Sep 11, 2015 08:26 PM
