how much dynamat?
Old Nov 18, 2008 | 03:44 AM
ryanschram's Avatar
ryanschram
Question how much dynamat?
how many sq. ft. would i need to do the entire interior of the Z? roof included.
Old Nov 18, 2008 | 05:22 PM
2006.350ZR's Avatar
2006.350ZR
Default do it right son....
well.... that will totally depend on how aggressive you plan to be with the damping. You might use anywhere from 80 to 150 sq ft or more. and it also depends on if you are layering different types as well.
If you are running a monster audio system, you will need much more deadening to do the job right. If you are just running a low power system its not as critical but many will add more anyhow to help with the noisefloor. (helps to block out road noise, engine & exhaust noise, and of course reflections, resonance and reverberation.)
Sooooo... I will tell you that if you do it right, your system will sound amazing and you will experience the true potential of your components.
just my .02
Old Nov 18, 2008 | 08:47 PM
orgasm_donor's Avatar
orgasm_donor
I used 104 square feet and I could probably use a little more. For the average guy with a decent small system I would say at least 50 square feet (doors and trunk). Roof would be more of course and cabin floor would put you well over 100 sq.ft. As 2006.350ZR said, do it right! If you don't do it right with quality materials (poly-butyl is the best!) then don't even bother doing it. Tar-based cheapie deadener is just a waste of good roofing material.
PureR3d
Sep 10, 2015 06:23 PM
supirio
Mar 12, 2004 08:57 AM
wesleyvt
Feb 5, 2004 04:35 AM
syf0n
Jul 15, 2003 03:13 AM
ccondo
Feb 20, 2003 01:59 AM
