Audio ipod Question
Old Jan 31, 2009 | 01:09 PM
tannerday's Avatar
tannerday
Default Audio ipod Question
Hey guys i want just a little jack that plugs into aux then my ipod or whatever and possibly to charge my ipod. Can this be done for cheap? i just need the parts i have a guy that knows car audio really good but im just lookin for someone that has done this and where they got there parts. Thanks. Anything helps.
Old Jan 31, 2009 | 01:11 PM
diwun67's Avatar
diwun67
Are you trying to plug your ipod into your factory radio?
Old Jan 31, 2009 | 01:13 PM
s31t8n8's Avatar
s31t8n8
do you have an aftermarket headunit or stock one?
Old Jan 31, 2009 | 01:15 PM
tannerday's Avatar
tannerday
I just have factory everything in it. Just seein if i can get a aux chord or charger thing maybe up in the cubby little whole cuz mines empty or somehwer else. i just need the right parts i guess. and price range of them.
Old Jan 31, 2009 | 01:17 PM
spinviper's Avatar
spinviper
I asked the guy in car audio shop to hook up my Iphone with stock radio, it 89 Dollars.
Is it the right price ?
Old Jan 31, 2009 | 01:19 PM
s31t8n8's Avatar
s31t8n8
that seems like a lot. i have an alpine headunit and the cable for the ipod was 30 bucks. you can get it for like $15 now.
edit: nmvd i thought you said ipod
Old Jan 31, 2009 | 01:24 PM
freedonutss's Avatar
freedonutss
Well you have an alpine headunit.... Hence why it is only $15 dollars. He has a stock radio therefore he would have to get a USA Spec iPod Interface cable and converter.
To answer your question if they can make an Ipod work with your stock radio(if you have a non-bose) for only $85 is a good price. The only other alternative to make a Ipod connect to your stock non-bose head unit would be to buy the USA Spec Ipod Interface cable.
Old Jan 31, 2009 | 02:04 PM
travislee's Avatar
travislee
never tried on a stock unit but ask the audio store if an Iplug will hook up to the stock unit...its by for the clearest sounding and easiest to use..if it works it will be real cheap
Old Jan 31, 2009 | 02:57 PM
JEKL's Avatar
JEKL
If your primary concern is cheap and you have a factory head unit, you should consider a WIRED fm modulator/transmitter and an powered iPod to RCA cable. It will allow you to charge your iPod if the car is on or not. I like it better than a wireless fm transmitter because it feeds the audio signal to the radio through the antenna which gives better quality.
You will not be able to control the iPod through the head unit, but with such a small display screen on the H/U navigating from there is very difficult anyway.
Look for something like this:
Old Jan 31, 2009 | 03:04 PM
SirSpeedyZ's Avatar
SirSpeedyZ
+1, that cable is aewsome
Old Feb 2, 2009 | 03:55 PM
Duffman27350's Avatar
Duffman27350
I looked on the site for the USA Spec Ipod Interface cable and it says it will work for 2004-07 350zs... not sure it its a typo or something but does it work for the 03' model???
Old Feb 2, 2009 | 04:11 PM
freedonutss
www.crutchfield.com
put the year and model of your car and go from there
Old Feb 2, 2009 | 04:18 PM
Duffman27350
yeah i went there and did all that and it didnt pop up.. then did it for an 04' model and pow there it is. so i guess im screwed on this for now... back to searching for a cable
Old Feb 2, 2009 | 04:36 PM
freedonutss
Really? I didnt know there was a difference in the 03 radios....
Old Feb 2, 2009 | 04:40 PM
Duffman27350
i didnt either but i did some further googling and found on 350ztech that it does work for 03' models even tho the website says 2004-2007. and saw another thread of someone using it in his 03 and said it is great. but u wouldnt happen to kno if there is a difference between the 6cd changer bose and the non 6cd changer or are they the same?
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
