HSK165 power question
Old Feb 10, 2009 | 07:51 PM
seank426's Avatar
seank426
Default HSK165 power question
So I'm planning on putting Hertz HSK165s in the front of my 350z powered by a JL 300/2v2. How much power do the tweeters take? That amp would be fine right? Puts out 150w rms x 2. HSK takes 120w rms even though I've read some people use up to 300w rms.
Old Feb 11, 2009 | 05:54 AM
seank426's Avatar
seank426
bump
Old Feb 11, 2009 | 02:39 PM
adamtaylorpcb's Avatar
adamtaylorpcb
tweet can handle 120w by its self
Old Feb 11, 2009 | 04:09 PM
seank426's Avatar
seank426
for some reason I always figured tweets took barely anything. So a JL 300/2v2 wouldn't even be enough?
Old Feb 11, 2009 | 06:22 PM
orgasm_donor's Avatar
orgasm_donor
That will be fine for that speaker set. The HSK set with crossover is a fairly efficient set so that JL power will be enough.
That said, you can always have more! If you ran a four channel amp and did a full active set-up, you would notice an increase in sound quality, volume, ability for adjustment and overall a fuller sound. Crossovers are heat bastards so reducing that will reduce distortion and lack of efficiency quite nicely.
Old Feb 11, 2009 | 06:27 PM
adamtaylorpcb
x2
tweet is 120rms driver is 100 rms
if you get a 400/4 and go active that would be perfect
or better yet, get the hsk-163 3 ways
Old Feb 11, 2009 | 07:24 PM
seank426's Avatar
seank426
wish I had the money, anybody have the link for the thread that described active vs passive. Never able to understand the difference. Also isn't the driver 125w rms?
Old Feb 12, 2009 | 06:08 AM
adamtaylorpcb
nope, i have the hertz book infront of me that lists all of the parameters for each speaker in the high energy line
the driver for the hsk-165 is the HV-165 which is 100w rms 200w peak, FR of 50-5,5k hz
active and passive is the crossover you use. passive is the little box that comes with components and is limited in how much tuning you can do. active is a stand alone unit that lets you set each crossover point independently
Old Feb 12, 2009 | 07:53 AM
seank426's Avatar
seank426
hertz website says 125w rms, 250 peak 50hz-22khz fr
Old Feb 12, 2009 | 08:29 AM
adamtaylorpcb
really?
Old Feb 12, 2009 | 08:52 AM
seank426's Avatar
seank426
thats weird, i just got to work so ill have to look into that later after i get off. It says 120w peak for the tweeter but what about rms?
Old Feb 12, 2009 | 08:57 AM
adamtaylorpcb
says that right next to it in the continuous column, 120w@2.5khz-12db oct.
so center the tweet at 2.5khz with a 12db slope at 120w
loudtoyz
Apr 6, 2023 04:52 AM
350Z_Al
Oct 29, 2020 07:44 PM
issyz
Jul 2, 2017 03:04 PM
codek
Sep 28, 2015 03:03 AM
