Is grounding necessary?
Old Mar 22, 2009 | 03:02 PM
xthejokerx's Avatar
xthejokerx
Default Is grounding necessary?
Hi guys, I'm trying to install a aftermarket single-din h/u and have bought the Metra #70-7550 wire harness. The Metra comes with a ground wire and so does the aftermarket h/u. I have soldered up these 2 wires. I have 2 questions right now:
1.) Is grounding still required? If so, how do I ground? I know to ground on these screws shown in the pic:
2.) Do I need to perform any other procedures before I can re-connect the battery, or can I do it right away after soldering the wires together to test the H/U?
3.) After I solder the wires, can I test the H/U by re-connecting the battery even though I didn't plug in the A/C and the 3 pod gauges?
Thanks
Old Mar 22, 2009 | 03:52 PM
Goku350z2007's Avatar
Goku350z2007
There are two ground screws right on the letter "G" abd the other screw is the number "2" you can use them as ground,
You can test the h/u without the A/C plugged in, it will just blow cold air at full speed just ignore it.
Old Mar 22, 2009 | 04:16 PM
xthejokerx's Avatar
xthejokerx
Thanks.
After I solder the 2 ground wires, do I still have to ground?
Also, do I need to solder the power antenna wires?
I have a wire from my H/U that says "To the remote lead of other equipment or automatic antenna if any". I've also got a wire that says "Power Antenna" from my Metra #70-7550. Do I solder these together?
From this DIY (https://my350z.com/forum/audio-and-v...all-guide.html), it says
you do need to connect the Power Antenna (blue) to the Antenna Control cable even tho we have fixed antennas.
So does this mean I have to solder the 2 wires I mentioned above?
This is the pic of the wire from my H/U. It's not a plug... Just copper wire with some kind of head attached to it...
Old Mar 22, 2009 | 04:40 PM
350ZREDLINE's Avatar
350ZREDLINE
I did, I first it wont hurt anything if it doesnt actually do anything, but I believe the 350z has some power amplification for the antenna..
Old Mar 22, 2009 | 04:44 PM
xthejokerx's Avatar
xthejokerx
If it's the wrong wires, won't it damage the entire h/u?
Also, how do I go about soldering them? The wire from the H/U has like a plastic piece covering it and then like a round metal head attached to it (in the pic above).
Old Mar 22, 2009 | 05:33 PM
Goku350z2007
you need to connect the power antenna wires or else you will not get any reception at all.
Old Mar 22, 2009 | 06:18 PM
Goku350z2007
use these screws to ground your wires.
416blueZ
Jun 11, 2024 10:56 AM
m_0g
Jun 3, 2021 10:05 AM
hulkout
Tuning
Sep 30, 2015 12:33 PM
OdesiTT
Sep 30, 2015 10:47 AM
cashmoney03
Sep 27, 2015 05:24 PM
