Where does this plug into?
Old Apr 17, 2009 | 03:43 PM
cms-35z's Avatar
cms-35z
Default Where does this plug into?
I installed XM and my I notice my AC wasn't working. I popped the console back off and there is a loose plug but I can find where it goes.
Please direct me to what it plugs into. It branches off the same loom that the AC amplifier plugs are connected.
thanks,
JC
Old Apr 17, 2009 | 03:52 PM
j.arnaldo's Avatar
j.arnaldo
...whoa, man...Hope you find the person who can help you. My technology savvy is very limited. Good luck!
Old Apr 17, 2009 | 04:10 PM
dmplaya786's Avatar
dmplaya786
uhhh it should plug into the back of the ac control unit i think...
Old Apr 17, 2009 | 04:32 PM
TreeFiddyZee's Avatar
TreeFiddyZee
Do WHAAAAT!?
^ Yup
Old Apr 17, 2009 | 04:40 PM
chriskd's Avatar
chriskd
This?
Old Apr 17, 2009 | 05:13 PM
quakerroatmeal's Avatar
quakerroatmeal
You are correct it goes back there.
Old Apr 17, 2009 | 05:20 PM
Spork's Avatar
Spork
Yep, that should be it.
Old Apr 17, 2009 | 07:05 PM
cms-35z's Avatar
cms-35z
No that's not it. That ribbon is plugged in.
This is a standard plug with wires that come out, not like the ribbon from the amp to the control *****. If you look in my picture, the ribbon is in the back ground and is plugged in still.
Old Apr 17, 2009 | 11:16 PM
adamtaylorpcb's Avatar
adamtaylorpcb
did you unplug it from anything?
looks like the harness for the light in the center console
Old Apr 18, 2009 | 12:44 AM
Brawl's Avatar
Brawl
Is it the plug that plugs into the emergency flashers?
Old Apr 18, 2009 | 03:23 PM
cms-35z's Avatar
cms-35z
I plugged the emergency flasher back in, and it works. This might not have even been connected to anything, because I can not find a female end that is still unplugged. It was later in the evening when I put every thing back together, so that's why I must of missed it.
The manual looks like it is M47 which is AT device, but I am not entirely sure what that is.
Old Apr 18, 2009 | 03:26 PM
surfcity40's Avatar
surfcity40
check on tech
Old Apr 18, 2009 | 03:49 PM
WhiskeyHotel's Avatar
WhiskeyHotel
You said the AC wasn't working?
Old Apr 18, 2009 | 03:56 PM
cms-35z's Avatar
cms-35z
Yeah, it just blows out hot air now. Every thing else is plugged in but this one wire, and I can not seem to find what it goes into.
Old Apr 18, 2009 | 05:21 PM
kevincat's Avatar
kevincat
it might not plug in to anything. i think in my 350z, i have a connector that is also not plugged in to anything. also in the g35 coupe, i have a connector that doesnt plug in to anything either, both cars are manual
Old Apr 18, 2009 | 05:23 PM
kevincat's Avatar
kevincat
or maybe it goes behind the white ac box. doesnt it have like 3 plugs behind it or something?
Old Apr 18, 2009 | 06:14 PM
firexbomber's Avatar
firexbomber
That plugs into your AC control dash, like the other ppl said. When unplugged, it makes the ac useless and only blows hot air. I have installed 2 stereos in my car so far, I had to take that cable off, while testing, it would only blow hot air (cuz it was unplugged). Let us know if you firgured it out or not, should just plug and fit like a glove. Btw how did it get unplugged?
burglapfd
Dec 6, 2020 01:04 PM
350z82
Oct 1, 2015 06:25 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
35reilly
Sep 28, 2015 07:42 AM
