My $100 like OEM fit NAVIGATION setup
Old Aug 17, 2009 | 08:00 AM
o2sys's Avatar
o2sys
Default My $100 like OEM fit NAVIGATION setup
EDIT 01/04/10: Download OCN8 Navi software here
http://www.megaupload.com/?d=B5NXJWYU
http://www.megaupload.com/?d=2H1R6VSN
unzip and copy the files directly to you SD card.
This is using a Plenio VXA-2100 GPS navigation and mounting it to the cubby.
Fits snugly & tight and works great! I modded the navigation software to use iGo8 instead of the crappy Smart2 navi system it came with. That's how i was able to use the NISSAN logo during startup.
Pics:
The navi is also connect to my JVC headunit which can play DVDs so whenever i want i just turn it on and i can use it a LCD screen as well!
This only works with Plenio VXA-2100 with external GPS antenna which i mounted it on the dash. The Plenio VXA-3000 is slightly bigger and will not fit into the cubby (i know from personal experience, i broke the unit trying to trim it to fit).
Old Aug 17, 2009 | 08:10 AM
dragonfire6's Avatar
dragonfire6
Default ...
Looks great!!
Couple questions... Is the unit new or used?? If new, where did you order it from?
Did you install this yourself?? Any pics from the install??
Thanks in advance,
Chris
Old Aug 17, 2009 | 08:32 AM
Asian Invasian's Avatar
Asian Invasian
wow that fits pretty nice.. i might have to pick one of those up.
Old Aug 17, 2009 | 08:39 AM
mw9's Avatar
mw9
Originally Posted by dragonfire6
Looks great!!
Thanks in advance,
Chris
what he said
Old Aug 17, 2009 | 08:40 AM
06blueZ's Avatar
06blueZ
wow that looks great.. any links on how to mod the unit with the better software? did the original software have any 'engrish'?
Old Aug 17, 2009 | 08:54 AM
Entaille's Avatar
Entaille
when I need navi I tend to just break out our tomtom unit and hold it up to the windshield screaming profanity at it to grab a signal. usually takes about 5 minutes before it grabs a signal, and tends to lose it if I let it sit too low in the car ..
good times. curious if this would fit into the flip-up version of the cubby (as opposed to the unit you have where it flips inside itself?)
Old Aug 17, 2009 | 09:50 AM
jcer's Avatar
jcer
how did you download the new software to make the logo come out like that?? Iam thinking of buying one now good job there!
Old Aug 17, 2009 | 10:06 AM
o2sys's Avatar
o2sys
Looks great!!
Thanks in advance,
Chris
I bought it new on ebay. There were tons for sale but now i dont see any except for this one:
http://cgi.ebay.com/Plenio-VXA-2100-...3286.m20.l1116
i paid $89 + shipping. The ebay one is more expensive.
As for the iGo8 software, i downloaded a copy from a torrent. then used instructions from this pdf:
http://www.gpspassion.com/upload2/pl...structions.pdf
you can follow the entire thread here:
http://www.gpspassion.com/forumsen/t...hpage=7#821009
VXA-2100 & 3000 are basically the same unit except for dimension differences and 2100 has external antenna. The 3000 will not fit in the cubby!
Old Aug 17, 2009 | 10:09 AM
o2sys's Avatar
o2sys
Yes the original software comes in English. You have to understand that you are only modding the navi software, the actual device program cannot be changed. Well actually it can be changed, i saw some one install Win CE.
Old Aug 17, 2009 | 05:16 PM
nismo_nate's Avatar
nismo_nate
ima copy this setup!
Old Aug 17, 2009 | 07:34 PM
o2sys's Avatar
o2sys
Go ahead i've been running this setup for couple months now and its been great!
Some cons:
1. The nav door doesn't open as smoothly, needs a slight push. But it closes without an issue.
2. Now that the navi unit is behind you can't hear the speakers too well. This unit has Audio Out so you can connect to the Line-In of you cd receiver (aftermarket headunits only) but that means you cant listen to both music and navi voice at the same time. If there was a way to convert the audio out of the navi and tap into the speaker wires...or some way of some sort please let me know!
Old Aug 17, 2009 | 08:45 PM
Kwame's Avatar
Kwame
If it has an audio out why don't you just hook up an amplified center channel speaker to it and hide the speaker in the footwell somewhere?
Old Aug 18, 2009 | 01:06 AM
quakerroatmeal's Avatar
quakerroatmeal
I don't see this thing for any less then like 180$-200$..how'd you get it for so cheap?
Old Aug 18, 2009 | 01:25 AM
Kwame's Avatar
Kwame
If you search under the completed listings in ebay you will see that there was a seller in Connecticut who was selling a "lot" of these (approximately six or so) and he/she was accepting best offers (accepted offers from $80 to $89) on the units.
Old Aug 18, 2009 | 02:31 AM
quakerroatmeal
That seller is no longer there? Boo.
Old Aug 18, 2009 | 04:39 AM
StreetOC192's Avatar
StreetOC192
Since you have a single DIN headunit, you could get one of these:
Alpine SBS-05DC Car Audio Center Channel Speaker
http://www.sonicelectronix.com/item_...mpaign=froogle
And power it with something cheap and small like this:
Pyramid PB440X Super Blue 2x35W Amplifier
http://www.parts-express.com/pe/show...number=265-079
The amp should be small enough to tuck away under the seat for ease of installation and you will have a dedicated center channel speaker for your navigation for around $155. Worth every penny if you rely on the voice guidance a lot. The amp doesn't say it's bridgeable, but you can run just 1 channel.
hmmmmm, now you got me thinking........
<<<< also have a single DIN
Old Aug 18, 2009 | 05:38 AM
Kwame's Avatar
Kwame
I'm using an Alpine SBS-0715 with the amplifier and speaker mounted underneath my dash for the voice guidance for my OEM navigation system. I had to do this since this there is no "mute" type feature on my Mcintosh headunit.
I think the unit I used is discontinued though, but it is perfect.
Old Aug 18, 2009 | 05:48 AM
burntZ's Avatar
burntZ
amazon has them new $119 - click the 'other options' / suppliers' link ( 280 for the main choice)
Nice set up!
Old Aug 18, 2009 | 06:14 AM
JasonZ-YA's Avatar
JasonZ-YA
O2SYS:
Thanks for the info! GREAT JOB! please post up some pics from the install if you have any? did you tape the unit it? glue? how did you secure it so it stays flush and doesnt push back when you "touch" the screen??? etc..
Plus awesome job on the software swap and Nissan logo addition!!!
STREET0C192:
POST 16 is baller!! great suggestion! would love to see pics of a set up like that...
-J
Old Aug 18, 2009 | 06:23 AM
JasonZ-YA's Avatar
JasonZ-YA
DOO EEETTT!!!!
post up pics, how to, etc.....
-J
