My $100 like OEM fit NAVIGATION setup
Old Aug 29, 2009 | 02:56 AM
  #61
solidsnake's Avatar
solidsnake
I just stumbled upon this, woohoo for a new mod ;-)
Old Aug 29, 2009 | 01:19 PM
  #62
Khanvict's Avatar
Khanvict
hows the GPS holding up? quality? i might go this route! thanks OP!
Old Aug 29, 2009 | 05:39 PM
  #63
o2sys's Avatar
o2sys
The GPS has been holding up great! I've had it for about 4 months now and not a single problem. No glitches or restarts.
Old Aug 30, 2009 | 04:33 AM
  #64
mw9's Avatar
mw9
Originally Posted by o2sys
i got the torrent from www.demonoid.com but currently the registration is closed.
It says if you get me a invitation code, I can join. Could you pm, one.
Old Aug 30, 2009 | 09:41 AM
  #65
o2sys's Avatar
o2sys
i removed the Audio out from the unit today and the built-in speaker is very audiable even when installed inside the cubby.
No need to buy a separate speaker or extra wires!
Old Aug 30, 2009 | 09:53 AM
  #66
0jiggy0's Avatar
0jiggy0
Is this only for the 03-05 cubbys? I have an 08, they're different right?
Old Aug 30, 2009 | 01:32 PM
  #67
o2sys's Avatar
o2sys
Well you saw it in person today so now you know....
Old Aug 31, 2009 | 03:31 AM
  #68
0jiggy0's Avatar
0jiggy0
Saw this in person yesterday. Really does look incredible. Everyone with a non nav setup should be required to do this.
Old Sep 1, 2009 | 10:17 AM
  #69
mw9's Avatar
mw9
Originally Posted by nismo_nate
yay i just got the navi in the mail!
there isn't any play with the navi mounted in the cubby, it fits pretty snug.
question for the op, how did you wire the navi. what did you use for power and how did you turn on the navi once its mounted?
thanks
any updates on progress
Old Sep 2, 2009 | 11:59 AM
  #70
burner's Avatar
burner
Got mine in yesterday, flashed with new GPS software and installed. This thing really works great, and looks good too. Install is simple. I'm still trying to figure out where to mount the GPS antenna as the cord it comes with is really short. I'll have some pics posted soon.
OP...where did you put your antenna?
Old Sep 2, 2009 | 12:20 PM
  #71
o2sys's Avatar
o2sys
Right in the middle of the dash. The center console still closes tightly even if the wire gets in the way. Of course the wire gets squished but not enough to cutoff. I just used some good double sided tape (3M automotive) and its doing great!
Old Sep 2, 2009 | 12:36 PM
  #72
06blueZ's Avatar
06blueZ
i really want to try this, but am hesitant because I have an 06 with the different dash... are the best deals still on ebay for $89
Old Sep 2, 2009 | 01:54 PM
  #73
burner's Avatar
burner
Thats where I have mine but its en eyesore....I know my old GPS antenna was mountable under plastic and I had it in the a-pillar. I might mess around with it tonight.
BTW....the iGO GPS software is awesome. Blows Garmin out of the water.
Old Sep 2, 2009 | 04:01 PM
  #74
mw9's Avatar
mw9
Did you use the instructions on the pdf, going to try to do my software tomorrow.
Old Sep 2, 2009 | 08:05 PM
  #75
o2sys's Avatar
o2sys
Doesnt bother me...you can hide it behind the cubby somewhere i suppose.
Have you seen the 3-D buildings yet? When i go into NYC i get all the buildings its very cool!
Old Sep 3, 2009 | 06:00 AM
  #76
burner's Avatar
burner
I haven't seen them in action yet but I did zoom in to my downtown area and the buildings were there, it is pretty cool. The refresh rate on this is better than any GPS i've ever seen, its very smooth.
As for the antenna, I found a great place to mount it. If you pop off the dash panel behind your gauge cluster, there is a little pocket directly behind the tach that it sits in perfectly. I pick up the GPS signal no problem!
Old Sep 3, 2009 | 06:04 AM
  #77
burner's Avatar
burner
The instructions on the PDF are good, but it doesn't mention a few other things that you have to do in order to get it working right. With help from the OP and some internet searching I was able to get it working, and change the boot screen to a Nissan logo.
OP: The nav that comes with the Plenio from the factory just plain sucked, I tried it out before I put the new software on. One thing it did do was boot directly into the GPS when the unit was powered on. Now, you have to tap the "navigation" button to get it working. Do you know if there is a workaround for this?
Old Sep 3, 2009 | 06:05 AM
  #78
burner's Avatar
burner
A friend of mine made it happen with his 05, just took out the center console and took a Dremel to it. Came out looking good, but it will take some modification. You could always get a cubby from an 03, too.
Old Sep 3, 2009 | 09:05 AM
  #79
Khanvict's Avatar
Khanvict
for people that downloaded the software, how long did it take u to download it form torrent? its been sitting for about 30 min and did not download anything.. its saying "availability 0.000"
Old Sep 3, 2009 | 11:49 AM
  #80
burner's Avatar
burner
If you are downloading a torrent make sure it has plenty of seeders or it will just sit there and do nothing until someone, somewhere jumps on and shares the file.
