My $100 like OEM fit NAVIGATION setup
Old Aug 18, 2009 | 06:31 AM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
Have you used other navigation systems? If so, how does this one compare?
Old Aug 18, 2009 | 06:35 AM
Kwame's Avatar
Kwame
Center Channel/Single Din in center console has been done before...
https://my350z.com/forum/audio-build...es-system.html
https://my350z.com/forum/audio-and-v...r-channel.html
https://my350z.com/forum/audio-and-v...shed-pics.html
Edit: Or if you are the ****ing Catalina Wine Mixer you'll install it in your sunglasses holder..
https://my350z.com/forum/121090-post3.html
P.S. Take note at how old those threads are. There are very few things that we can think of at this point that has not been thought of or done at some point with this car.
o2sys's Avatar
o2sys
Originally Posted by JasonZ-YA
O2SYS:
Thanks for the info! GREAT JOB! please post up some pics from the install if you have any? did you tape the unit it? glue? how did you secure it so it stays flush and doesnt push back when you "touch" the screen??? etc..
Plus awesome job on the software swap and Nissan logo addition!!!
STREET0C192:
POST 16 is baller!! great suggestion! would love to see pics of a set up like that...
-J
I originally bought the VXA-3000 which turned out to be too bulky and i ended up breaking the unit trying to trim the plastic to fit.
The VXA-2100 has very close dimensions to the infamous Farenheit LCD monitor so the install is exactly the same. I used 3M double sided tape (red film) around the frame and attached it through the back.
The touchscreen is very good on this unit, reacts to simple fingernail taps so it wont push back unless you press it hard like a retard. You will crack the screen before the unit falls off.
Here is a video i found during my researching days:
http://www.youtube.com/watch?v=t9y5pf6wNcU
Old Aug 18, 2009 | 07:14 AM
06blueZ's Avatar
06blueZ
so once the unit is mounted i guess you dont have access to the SD slot? does it automatically power on and off with the car if the power adaptor is on a switched circuit?
Old Aug 18, 2009 | 07:20 AM
3hree5ive0ero
Retired Admin
Does this set up (either as-is or your modded version) have lane guidance? How's the actual routing (detour, adding poi, route recalculation, etc) of the navigation? Also, are all the buttons, slots, etc accessible the way you have it in the cubby? Lastly, any and all information regarding your install would be appreciated.
Old Aug 18, 2009 | 07:30 AM
Jun's Avatar
Jun
pretty sweet!
Old Aug 18, 2009 | 07:48 AM
SirSpeedyZ's Avatar
SirSpeedyZ
looks great, good work
Old Aug 18, 2009 | 08:44 AM
o2sys's Avatar
o2sys
This unit does not have a built in battery. It comes with an a/c cigarette adapter. So i just bought an extra outlet and tapped the lines. So shuts on and off with the car. You can inline fuse the power source with a switch if you want to turn it on/off yourself.
Here is a link to the navigation software. It has buildings and all its really sweet!
http://www.oncoursenavigator.com/
Old Aug 18, 2009 | 08:57 AM
o2sys's Avatar
o2sys
Originally Posted by StreetOC192
Since you have a single DIN headunit, you could get one of these:
Alpine SBS-05DC Car Audio Center Channel Speaker
http://www.sonicelectronix.com/item_...mpaign=froogle
And power it with something cheap and small like this:
Pyramid PB440X Super Blue 2x35W Amplifier
http://www.parts-express.com/pe/show...number=265-079
The amp should be small enough to tuck away under the seat for ease of installation and you will have a dedicated center channel speaker for your navigation for around $155. Worth every penny if you rely on the voice guidance a lot. The amp doesn't say it's bridgeable, but you can run just 1 channel.
hmmmmm, now you got me thinking........
<<<< also have a single DIN
Can i just buy the amp and connect it to my regular speakers? This way I can run both the navi voice guidance and music at the same time without needing to switch sources.
I dont want to use the center speaker as i use the slot to hold my phones and wallet.
Old Aug 18, 2009 | 09:18 AM
JasonZ-YA's Avatar
JasonZ-YA
I don't want to use the center speaker as i use the slot to hold my phones and wallet.
Why don't you just get the small speaker that Kwame@z1Auto suggested then.....mount it under the dash like he said he did.
The Alpine SBS-0715 he mentioned in post 17.
You wont need to switch anything.....the speaker will sound out voice guidance, about the only thing you will need to do is lower your radio volume to hear the nav......but not switch sources.....
Originally Posted by Kwame@z1Auto
I'm using an Alpine SBS-0715 with the amplifier and speaker mounted underneath my dash for the voice guidance for my OEM navigation system. I had to do this since this there is no "mute" type feature on my Mcintosh headunit.
I think the unit I used is discontinued though, but it is perfect.
-J
Old Aug 18, 2009 | 09:50 AM
Kwame's Avatar
Kwame
Good luck finding it. When I purchased mine in 2007 it had been already discontinued.
Old Aug 18, 2009 | 01:01 PM
burner's Avatar
burner
First off, great work...especially with the software update.
I am running the fahrenheit/Garmin combo now, but everyday I wish it was a touch screen. I may pick this up and give it a try. A few questions, though if you don't mind...
On the Garmin, there is a mute wire so that the music from my aftermarket deck is muted when the GPS needs to say something. Does this unit have a mute wire? Is the audio out a headphone jack or RCA's?
How long does the unit take to boot up? Is there a way to bypass the warning screens and go straight to the navigation screen?
How long does it typically take to pick up a GPS signal?
When moving, how is the refresh rate on the GPS? I know some systems get notchy when driving around.
If you have used other GPS systems (portable, or OEM) how does this compare as far as interface, looks and map updates?
That link you posted with the software, will this device run that new version?
Thanks for the info, again great work.
Old Aug 19, 2009 | 06:25 AM
o2sys's Avatar
o2sys
There is no mute button, the "audio out" is RCA's. The RCA is connected to my headunit "line-in" so i have either music only or navi voice guidance only. So on long trips if the navi has nothing to say then its just silence
How long does the unit take to boot up? Is there a way to bypass the warning screens and go straight to the navigation screen? I'm sure you can tweek the program (Win CE) to do what ever you want. But i havent been able to bypass this. Everytime it shuts off, it will go to the main screen and i have to click the NAVIGATION icon. Its pretty quick to load.
How long does it typically take to pick up a GPS signal?The GPS is very fast, usually when its started up it already has full strength signals
When moving, how is the refresh rate on the GPS? I know some systems get notchy when driving around.Its not notchy, pretty smooth
If you have used other GPS systems (portable, or OEM) how does this compare as far as interface, looks and map updates?I dont have much experience with other, I just had a PNA Mio unit. Can't really do a comparo though.
That link you posted with the software, will this device run that new version?You can run any GPS software you'd like. You just need to code it so the software can read it. Lots of people are using iGuidance and other popular navi programs successfully on the VXA-2100/3000
Thank you!
Old Aug 19, 2009 | 08:08 AM
burner's Avatar
burner
Hey thanks a bunch for answering the questions. Looks like I'm going to be searching for one of these and unloading my Farenheit/Garmin combo!
On a side note....if you are using RCA's to power your speakers (some wiring harnesses use them) then you could buy a splitter and wire the sound from the GPS directly to either your front or rear speakers and have the voice come out of them. It would not mute the music (voice would talk over), but better than an extra speaker. Quite a few OEM setups use something like this.
Old Aug 19, 2009 | 08:40 AM
o2sys's Avatar
o2sys
Thats what im looking for. But don't know what to search for!
Old Aug 19, 2009 | 06:05 PM
nismo_nate's Avatar
nismo_nate
i just bought a 03 cubby and waiting or it to come in. next is the navi, hope i can find it cheaper than 100 lol
Old Aug 22, 2009 | 08:03 AM
nismo_nate's Avatar
nismo_nate
i just bought the plenio navi on ebay... now i have to find a good headunit!
Old Aug 22, 2009 | 03:17 PM
  #38
o2sys's Avatar
o2sys
Get one with a DVD player.
Old Aug 23, 2009 | 07:24 PM
  #39
burner's Avatar
burner
All you need is two RCA Y-splitters which you can buy just about anywhere.....if you want the details I can send them just PM me, this is how I have mine set up right now.
Old Aug 25, 2009 | 12:33 PM
  #40
burner's Avatar
burner
There is guy on eBay selling these right now, he has several for $89.
