Differences in HDMI cables?
Old Sep 4, 2009 | 06:01 PM
  #41
Spike100's Avatar
Spike100
Originally Posted by snobird
pretty good price
i work in electronic sales for living and we buy at actual cost, we have people all the time who have to have the monster 1000 hdmi that sells for like $129 and the markup is insane in it too. I think our cost is around 30 to 35 for the 6ft cable
but a cable is a cable for the most part, now if you are running the cable through the wall i would recommend spending a little extra to get better shielding
Originally Posted by StreetOC192
If installing in-wall, the cable needs to be CL2 or CL3 rated.
Street’s correct. HDMI cables are not rated for in-wall installation. You should not run an HDMI cable inside a wall (and “shielding” isn’t a relative term here).
If you need to run HDMI cabling inside a wall, you install HDMI boosters at each end of the run, and connect these with CAT6 wires (Ethernet twisted pairs). You need to run two wires in the wall, one for sound and one for video. The HDMI boosters accept RJ45 connectors (same that you use for your computers connected with Ethernet twisted pair wiring, the only difference is you need two wires for a single run).
Doing this allows you to run your HDMI up to about 150 feet, and it costs much less and is more reliable than doing this with a “straight” HDMI cable with integrated boosters.
--Spike
Old Sep 4, 2009 | 09:37 PM
  #42
koren's Avatar
koren
Originally Posted by Chasecbc
I have a Samsung blu-ray player and i am using a cheap HDMI cable and i noticed it takes forever to load at the beginning. Would it be faster if i bought a cable with a faster transfer rate? is the difference worth it?
You have to buy more expensive blu-ray player for a fast BD loads..
Old Sep 6, 2009 | 01:56 PM
  #43
Spike100's Avatar
Spike100
No. The HDMI cable has nothing to do with a BD device’s performance as to speed when loading. Electrons move at the speed of light, no matter what HDMI cable they travel upon.
The delay you see with your BD device’s loading routine is mostly related to its features and the BD version. And, that really has little to do with the device’s cost since more expensive devices that do more functions (e.g., internet connection, live input/output, etc.) at startup may be slower when loading. In fact a more costly BD device with more features may have a longer startup than a less costly device.
--Spike
Old Nov 27, 2009 | 07:30 AM
  #44
yomike007's Avatar
yomike007
lmao at this thread.
Cheap HDMI monoprice cables will produce the EXACT same picture quality as the $140 Monster cables from best buy.
Now if you want to compare analog signal quality, then yes, more expensive cables will improve picture quality slightly.
Old Nov 27, 2009 | 08:33 AM
  #45
Jinxx's Avatar
Jinxx
http://www.avsforum.com/avs-vb/ for all your tech spec problems
2ndchanceZ
Oct 26, 2015 08:03 PM
350z82
Oct 1, 2015 06:25 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
