Ordering my Basslink.....
Old Oct 11, 2003 | 09:37 AM
jikman01's Avatar
jikman01
Default Ordering my Basslink.....
I'll be ordering my Basslink this week coming and I was wanting to know if a standard amp wiring kit will do the trick to get it installed?
It comes with all of this:
16-foot Strike RCA patch cable
20-foot braided crystal blue 10-gauge power wire
3-foot silver 10-gauge ground wire
ATC fuse holder with 30-amp fuse
16-3/4" 18-gauge turn-on lead
ring terminals
connectors
wire ties
4-3/4 foot split loom
protective grommet
Seems like it will work and it costs $30
Am I better off going to get this stuff somewhere else? Any suggestions?
Also, when wiring the power to the battery, do I just use the 2nd bolt that's on the positive termimal or where do I put it?
Thanks!!!
Old Oct 11, 2003 | 02:55 PM
kopo's Avatar
kopo
my basslink came with the 10g power wire. everything works fine, no problems what so ever. As far as the power wire and battery, just attach the power wire to the red (positive) part on the battery using one of the rings that come with the amp kit. PM me if u have any other questions.
Old Oct 12, 2003 | 11:14 PM
VinaZ's Avatar
VinaZ
May I ask where do you order and how much it costs ?
Old Oct 13, 2003 | 04:38 AM
jikman01's Avatar
jikman01
eBay.
If you want a amp wiring kit to get it all installed you can get both for $188.95
If you don't need the kit, then I've seen the basslink for as low as $171.95 (Brand new - buy it now option only)
This is a good deal I belive considering that the cheapest amp wiring kit is $20+ and Circuit City sells the Basslink for $300+
Old Oct 13, 2003 | 04:40 AM
jikman01's Avatar
jikman01
I may have to post this as a separeate thread, but let's give it a try here.
What is the final word on where the best location for the Basslink is?
Anybody who's ever tried it in more than one place, where do you get the best sound?
Stock sub location or rear hatch area?
Old Oct 13, 2003 | 05:37 PM
only1's Avatar
only1
Yeah, Im tryin to decide the same thing, wheather to put it in the hatch area or behind the drivers seat. So any ideas?!
Old Oct 13, 2003 | 06:16 PM
jikman01's Avatar
jikman01
I couldn't imagine that if you close it up in an enclosure that you would get as good of a sound as if you put it cornered in the hatch and fired it up or put it between the strut bar and the rear speakers and fired it rearward.
I guess I'll just have to find out myself!
Old Oct 14, 2003 | 09:58 AM
only1's Avatar
only1
Well wont be doing mine for another 2 weeks, so keep me informed on how it sounds...
Old Nov 12, 2003 | 10:27 AM
VinaZ's Avatar
VinaZ
Originally posted by jikman01
eBay.
Thanks
Old Nov 12, 2003 | 11:44 AM
AndyB's Avatar
AndyB
Default $200
Check out shopping.yahoo.com
I see em there for like $200, and that is from a dealer with a 4+ star rating on yahoo.
Lots of good prices on yahoo, and probably a little safer than eBay.
Old Nov 12, 2003 | 12:38 PM
wren57's Avatar
wren57
I heard a basslink that was in the rear hatch pointed upward and it sounded incredible!!!
Old Nov 12, 2003 | 03:43 PM
jikman01's Avatar
jikman01
Wren, That was me!!!
Old Nov 12, 2003 | 03:53 PM
wren57's Avatar
wren57
DOH!!! Haha, I didn't even look at your username/location when I posted...
Old Nov 13, 2003 | 12:10 PM
RedHerring2's Avatar
RedHerring2
I have a basslink mounted in the stock sub location and it sounds incredible. Much more than I ever expected. It is clean and powerful. I ran 4 gauge from the battery along the passenger side and through the white plastic wire guides and broke off an 8 gauge to power my basslink. I installed a 1 farad capacitor while I was at it.
I was able to set my crossovers for my 4 front and rear speakers to have just a little overlap around 160hz with the basslink.
Get a copy of Exit Stage Left by rush and listen to the drum solo on there. Hi and low drums shifting within the stereo image. It worked great to tune the system.
I have a lemans sunset roadster. Alpine reference components all around. Alpine CDA-7897 Head unit. Alpine V12 50X4rms amp + basslink. Plenty of power so I can hear over road noise with the top down.
I paid $190 off ebay for new in the box basslink.
Old Nov 20, 2003 | 01:42 AM
Shift33's Avatar
Shift33
Does anyone have pictures of their install? I'm looking to get one of these to tie me over until I have more money in the future for building my own custom box. I would like to put it in the stock location but not sure about the size and how to mount it.
Old Nov 20, 2003 | 10:46 AM
Beaker02's Avatar
Beaker02
So do you have it mounted strait up with the stock grill to the side, or is there room to point it out the grill?
Old Nov 20, 2003 | 03:38 PM
jikman01's Avatar
jikman01
Mine's not in the stock sub location. I mounted it in the hatch area. Sounds really good.
This is not a pic of mine, but I have mine in the exact same location.
Old Nov 20, 2003 | 06:52 PM
ElvishasaZ's Avatar
ElvishasaZ
how does this unit work exactly can you hook it up to the stock head unit without the bose? And would it sound ok in the sub location that the factory made?
Old Nov 21, 2003 | 07:26 PM
jikman01's Avatar
jikman01
it has both low level (RCA) and high level (speaker leads) inputs. This means that you could use it with an aftermarket radio which has RCA outputs like the Alpine unit that I have for example that has a RCA output specifically for the subwoofer or with a factory head unit with only speaker outputs (high level).
Basically you hook up either the high level or low level inputs, you run a wire to the battery, one for the ground and one for the remote turn on (only needed for low level inputs) and that's it!
As for the location, In my opinion, you will get the best sound in the hatch area as it allows for the low frequency waves to build and give a deeper fuller bass, but the stock sub location isn't bad. Only thing is that the bass will not carry and not be as full as in the hatch area.
ablaine
Nov 29, 2016 10:13 AM
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
