Running lights/radio lights not working help!
Old Dec 8, 2009 | 04:14 PM
Z33hr6spd's Avatar
Z33hr6spd
Default Running lights/radio lights not working help!
I just realized my running lights in the front and back arent turning on with the switch but all the bulbs are good and brake pedal still works the brake lights...also the radio doesnt light up all the buttons and the cup holder light isnt on but everything else in the interior lights up correctly, i've checked some fuses anyone got any ideas?
Old Dec 8, 2009 | 06:00 PM
Spike100's Avatar
Spike100
^^ When you connected your new equipment, you inadvertently disconnected some existing grounds that resulted in disabling some of your car's electronics.
--Spike
Old Dec 9, 2009 | 12:03 PM
KPierson's Avatar
KPierson
Did you put in an aftermarket radio? Did you hook up the illumination wire?
When checking fuses did you use a meter or just visually check them? Sometimes you can't visually tell a fuse has been blown.
Your problem is similar to what happens when you incorrectly hook up the dimmer wire when installing a head unit - if this is the case you should be able to disconnect the illumination wire and replace the fuse and be good to go.
Old Dec 9, 2009 | 06:13 PM
Spike100's Avatar
Spike100
^^ Good advice on the H/U installation. You understand.
When installing a new H/U, there are often questions such as:
  • What is this wire for?
  • Where should I connect this wire?
  • How come I have a “left-over” wire that doesn’t seem to connect to anything?
Aftermarket wiring harnesses make the job much easier, but they do not always blend perfectly to the OEM harness. They can only do so much.
There is no substitute for a Professional Installer who has seen many of the variations and knows what to do achieving a successful installation of complicated equipment.
--Spike
Miguel Albanez
Oct 17, 2022 10:13 AM
350z_z33.
Jul 3, 2017 04:01 AM
bcoffee20
Nov 19, 2015 06:39 PM
Bodyboarder81
Sep 21, 2015 06:23 AM
Shane86
Sep 17, 2015 05:33 PM
