Cheaper 7" VGA touchscreen
Old Jan 10, 2004 | 05:00 PM
  #121
CopperZ's Avatar
CopperZ
I’m having problems with the laptop in the glove box. I have to open it (the screen) to get to the power button. I was thinking of putting it under the seat? Any idea’s on how to install something like this other then the seat and taking it in and out every time.
Old Jan 11, 2004 | 08:40 AM
  #122
murrman100's Avatar
murrman100
What kind of laptop is it?
Does it have any kind of docking bay or port that you could hook it up to?
Old Jan 11, 2004 | 08:49 PM
  #123
CopperZ's Avatar
CopperZ
its an HP omnibook xe2. I dont have a docking station for it. I will look for one. But what does the docking station do?? Another problem that happened twice already, when i get into my car that has been sitting for a while, the laptop will not boot, it shows me a black screen that says: "drive error , press ctrl+alt +delete". did you have any problems with starting on a cold day? (it was about 35F today in Chicago) I started the laptop while i was driving and i thought it was the shaking that was preventing the start. But then i got home it started, so i shook the hell out of it and windows xp started with no problems ( i even dropped the comp about 4ft while it was starting on accident AND IT STILL STARTED!!!)
Old Jan 12, 2004 | 02:30 PM
  #124
DMD's Avatar
DMD
Just put the lilliput in my car, looks unbelivable, the touch screen is great and coupled with a Earthmate GPS system I have GPS...I could not be happier, if anyone is considering buying a lilliput I highly recommend it. I wish I had a digicam to show you guys pics. Maybe I can borrow my friends and post some pics. I have a very clean install, but I did have to open the lilliput case and discard the front.
Old Jan 12, 2004 | 03:00 PM
  #125
MannishBoy's Avatar
MannishBoy
How is glare in direct sun? That is one of the things I'd worried about with the Xenarc.
Old Jan 12, 2004 | 03:08 PM
  #126
pulpz2's Avatar
pulpz2
Originally posted by DMD
Just put the lilliput in my car... I have a very clean install, but I did have to open the lilliput case and discard the front.
Is it mounted in the NAV compartment or did you pull the hu from the double DIN?
  #127
CopperZ's Avatar
CopperZ
i ordered my screen today $300 for everything. It has to come from Hong Kong so it should take a while to get here.
Old Jan 12, 2004 | 05:51 PM
  #128
DMD's Avatar
DMD
I put it in the NAV compartment...looks great, minimal glare. I got mine from Hong Kong also, through the ebay guy...worked perfect. I haven't tried direct sun as today was overcast in Cinci.
Old Jan 24, 2004 | 04:11 PM
  #129
zpylot's Avatar
zpylot
Those of you that put your screens in the NAV compartment I have a question. Did you start with a nav screen there already and swapped it our for the new screen? Or is your car without the nav option and you put the screen in the non-nav compartment?
I am asking because I have a 2004 non-nav roadster. After reading numerous posts I decided to install a Xenarc Touch screen. I bought it, took my dash apart in prepartion of installing the screen. The non-nav compartment is all one unit with the door. There is no place to mount the screen. I am assuming this is because Nissan changed the non-nav compartment to the non-motorized door for the 2004 models.
So is there anybody out there who has installed the new screen in a non-nav car that I can talk with? I am in need of some help. My first thoughts are to by the non-nav compartment for a 2003 Z. Anybody know the part numbers for that?
Anybody got some ideas for me?
Thanks for any and all help.
Old Jan 24, 2004 | 10:47 PM
  #130
CopperZ's Avatar
CopperZ
i just put in my screen today. It was a Non-nav. Its a 2003 T. I dont know about the 2004 model, but when you take out the whole assembly (radio, nav compartment, 3 gages) you should be able to remove that empty box. there are 4 screws that hold it in. Where do you live i can help you puit it in. I got the Lilliput touchscreen and i love it. its amazing..... I will post some pic's latter.
Old Jan 26, 2004 | 11:44 PM
  #131
genbo's Avatar
genbo
What Lilliput model number is being used on the 350Z in the Nav compartment area. I'm looking for a VGA monitor. Not too sure if I want the touch screen.
Been looking around on the net and I have seen a few different
model numbers. Some of these are just video displays and not monitors.
Any other suggestions?
regards, Perry
'03 SilverStone Performance
Old Jan 27, 2004 | 10:30 AM
  #132
zpylot's Avatar
zpylot
I am in Sacramento, CA. I have the non-nav compartment out. But after reading many threads I have come to the conclusion that Nissan changed the design of the non-nav compartment from the 2003 to 2004 models. It is all one piece after taking the four screws out. Here are two pictures demonstrating what I am talking about. I don't see how to take apart the compartment so that I can mount the screen. The fold up door is integrated into the box. I hope I am being stupid and missing the obvious.
Old Jan 27, 2004 | 10:31 AM
  #133
zpylot's Avatar
zpylot
Pic 2
Old Jan 27, 2004 | 10:34 AM
  #134
zpylot's Avatar
zpylot
Pic 3
  #135
zpylot's Avatar
zpylot
Pic 4
Old Jan 27, 2004 | 12:37 PM
  #136
genbo's Avatar
genbo
Pic 4
I've been following the threads also. Getting ready to add a screen to my '03. The nav door set up you have pictured is different from mine.
Take a look at this thread
https://my350z.com/forum/showthread....threadid=55441
It shows the setup you have. (and some recomendations)
This page shows the door setup simular to the one I have.
http://liljerk.morpheus.net/350Z/dash_removal/
From what I've seen, it looks like the the second of these is the one that works the best.
What type of screen are you putting in? I'm thinking of the Lilliput, but not too sure which model the guys have been using.
Another idea I came up with was the screen from a Toshiba Libretto laptop......nice size, good resolution...but not the best in bright light conditions. It would sure fit in easily.
regards, Perry
Calgary, Alberta, Canada
oh it's only -32 C here today.....glad you asked
Old Jan 27, 2004 | 01:18 PM
  #137
zpylot's Avatar
zpylot
I bought the 7" Xenarc touch screen. So now I need to goto Nissan and get either the 2003 non-nav compartment, or the 2004 nav compartment. Sorry it's so cold there.
Thanks on those two links. The second is indeed what I have. It has that ugly felt on it too.
Old Jan 27, 2004 | 09:50 PM
  #138
CopperZ's Avatar
CopperZ
I can agree that you will need to get the 2003 one. Sorry, man i know how you feel. take everything apart just to find that it cant work.
Old Jan 28, 2004 | 01:55 AM
  #139
genbo's Avatar
genbo
Can you tell me the model number of the screen you bought and where you bought it from?
619GL-70NP, 618GL-70NP or ?
Not too sure what the differences are.
Looking to do the mod on my Z also. The Canadian dollar is up right now which makes it a great time to buy toys from the States.
regards, Perry
Old Jan 28, 2004 | 02:02 AM
  #140
genbo's Avatar
genbo
Just out browsing the Liiliput site.
The last line on this page http://www.lilliputweb.net/rd.html
says "Any ideas for improving and developing products are welcomed and will be highly appreciated."
So I sent em a suggestion........ ..... make a bolt in monitor for the 350Z. They already have the screen. Just make some new plastic that is 350Z friendly.
I'd buy one. Maybe if they get enough requests.
