BOSE head unit replacement questions.
Old Feb 9, 2010 | 12:04 PM
92K1500's Avatar
92K1500
Without being able to see the other end of it I couldn't tell you yes or no.
FYI if you buy from crutchfield you get everything needed to install for free.
Old Feb 9, 2010 | 12:43 PM
arsey51's Avatar
arsey51
If your stuck on the Pioneer head unit - amazon has it on sale for 250.00 versus Crutchfield's price. If money isn't an issue, I would recommend FOCAL separates/components for the doors.
Old Feb 9, 2010 | 01:28 PM
kham25's Avatar
kham25
Thanks for your help.. I do find that crutchfield sells more expensive than others reason why i have not purchased anything with them...
Old Feb 9, 2010 | 02:40 PM
92K1500's Avatar
92K1500
I always check with them because sometimes they are cheaper, and they give free stuff with it.
Old Feb 10, 2010 | 04:32 PM
s14wannab's Avatar
s14wannab
To add to this discussion (instead of making a new thread) I just want to get the radio in working order. I'm not worried about sound quality. I am encountering problems like; static when the HU is off; no response when turned on; and the bass pops loudly occasionally. So I just want the cheapest means of fixing it while still have reputable companies' parts on it.
That is the question/statement.
Old Jul 25, 2011 | 03:54 PM
myfirstzcar's Avatar
myfirstzcar
I just looked at that link, do you know if that harness will allow the nav to speak through my new head unit?
Old Jul 25, 2011 | 08:55 PM
Deteria's Avatar
Deteria
Sorry for thread jacking, could I buy a pioneer double din + some focal $400-500 speakers + a 4 channel amp, have the 4 channel amp power the new speakers for the time being, and then have the HU power the 2 speakers behind the driver seat + the blose subs?
Then a few months down the road, get a pair of aftermarket speakers to replace the ones behind driver seats (have them powered by the 4 channel amp), and get a 10W7 + a mono amp?
Old Jul 27, 2011 | 04:50 PM
myfirstzcar
If your new deck has pre-amp outputs you can run them to a seperate amp. Then just plug (with the adapter harness) and play to make your blose system work.
350z82
Oct 1, 2015 06:25 PM
