Bought a Magellan 1700 GPS 7 inch screen fits in Cubby
Old Jun 3, 2013 | 09:16 PM
  #101
Linuxglobal's Avatar
Linuxglobal
Originally Posted by djwatts
Nice man, how you do the wiring?
Not sure where to start, but basically the kenwood unit sits in the rear and everything was extended from the front to make it as much plug and play as possible.
The headunit is accessible by just removing the rear plastics. I had to cut a bit of the rear metal to fit the unit. The screen was extended with a custom 2.5 meter cable (70pin). The original nissan hu just sends the audio to the kenwood through the aux port as a video 1 input. Steering wheel controls are connected to the kenwood only. Stock audio kno_b controls outline of the main unit into the kenwood.
Remote has ir sensor using the nissan controls linked to the kenwood ir remote with a voltage drop so it gets 3.0v when the car is turned on.
I have a lot of schematics from the project, I kept it in case any of my friends want to do this to their Z, it took a decent amount of time to get it all planned, wired, installed, and tested. Some parts took a bit of time to order as well.
I wrapped all of the lines in wire loom, ran it from the front to the back, installed all the plastics again and it was testing time.
PM me with any questions or I can answer them here. I started a build thread but people did not reply, so I didnt bother posting more detail on it.
Old Jun 8, 2013 | 02:22 PM
  #102
kham25's Avatar
kham25
OP here nice to see how many people have followed through with this MOD after all this time.
Anyways i ended up getting a double din installed & now my Magellan was sitting collecting dust.I decided to install it in the Upper chubby and go from there.
The screen is not as washed out in the Upper chubby being recessed as it was in the 06 Chubby as mounted on the first page. This was my number one issue with the Magellan i could'nt see **** driving during the day. Spike lol..
I was not going to pay $325 for non functioning buttons + $50 for Mask Finisher.
I got the Nav dash from the Dealer this week & started hacking away.This is what i came up with. Installed this morning. Some spots i have to touch up,dash scratches so damn easily
Old Jun 8, 2013 | 02:26 PM
  #103
l2iceman's Avatar
l2iceman
Nice! I just got the navi piece from Mike at concept z performance. Also picked up a Magellan 1700 this week. I'm waiting on the rear view camera from eBay lol as for the button panel area, I'm going to fab something up and wrap it in black leather while relocating the gps unit's speaker somewhere
Old Jun 8, 2013 | 02:31 PM
  #104
kham25's Avatar
kham25
Best way to do it man.. That money saved now going to other MODS
BTW you can clearly hear the speaker behind the dash no need to relocate.. I tested it out before putting everything back together
Old Jun 10, 2013 | 03:03 PM
  #105
l2iceman's Avatar
l2iceman
did you hardwire the GPS to the car? I've been reading into this, the Magellan's car adapter converts from 12v to 5v, so I can't just cut the cigarette socket part and hardwire it like that. I'm guessing I have to get an inline fuse or just get a socket extension in order to maintain the converter in the cigarette socket.
Old Jun 10, 2013 | 03:06 PM
  #106
Linuxglobal
Just solder the 12v ACC line from the radio harness to the leads of the 5v adapter to turn on when the car turns on. It doesn't need a socket extension, you can just solder the positive to the center of the cigarette light adapters and - to the outside pins.
Old Jun 10, 2013 | 03:19 PM
  #107
l2iceman's Avatar
l2iceman
my concern is that the input on the plug is 12v and it outputs 5v to the GPS unit.
So my understanding from what you're saying, if I cut off the part circled in red in the pic attached and hardwire that to the radio's power, wouldn't it be sending 12v to the GPS and possibly fry it?
Attached Thumbnails Bought a Magellan 1700 GPS 7 inch screen fits in Cubby-untitled.jpg
Old Jun 10, 2013 | 03:26 PM
  #108
Linuxglobal
Dont cut off the entire red part, in fact dont cut any of it, just solder the 12v power to the silver parts of the red section you highlighted.
That way the 12v will go to the adapter and the gps will get 5v.
Old Jun 10, 2013 | 03:31 PM
  #109
l2iceman's Avatar
l2iceman
ahhh ok I see, that makes sense. ok great, thanks!
Old Jun 10, 2013 | 08:29 PM
  #110
l2iceman's Avatar
l2iceman
Gonna end up using an extension so that I don't have to ruin the original adapter in case I decide to swap units and sell off in the future. And by going the extension method, I can simply cut it and hardware it directly to the radio power...plus I don't have a soler nor have I ever soldered anything lol
Old Jun 10, 2013 | 08:32 PM
  #111
Linuxglobal
That will work as well Just make sure you tape it together just so it doesnt slip out of the 12v socket over time. Solder cleans up well but i see your point down the road.
I made so many little adapters for my headunit swap, you can actually make your own 5v step down driver if you want to get creative.
Old Jun 12, 2013 | 03:49 PM
  #112
Spike100's Avatar
Spike100
It’s wise to keep the Megellan’s power adapter intact. The adapter does in fact step-down the voltage, and also controls power spiking insuring a uniform power supply protecting the device and optimizing its processes.
The inexpensive and simple way to do this purchasing a generic power adapter.
Simply plug the Magellean into its own power adapter, plug the Megellan power adapter into this generic power plug (shown above), and wire the generic power plug to a power line from your car’s ignition, and ground the generic plug. Done!
--Spike
Old Jun 12, 2013 | 06:29 PM
  #113
l2iceman's Avatar
l2iceman
Hey Spike, thanks for the idea. My idea is similar except I'm getting an extension(see attached), and cutting off the socket in the red box. I'll then hardwire the power into the radio's power and ground to the chassis.
This way, I'll still maintain the Magellan unit's step-down.
edit: I already ordered an extension online, otherwise I'd go with your idea to avoid cutting anything
Attached Thumbnails Bought a Magellan 1700 GPS 7 inch screen fits in Cubby-extension.jpg
Old Jun 12, 2013 | 07:36 PM
  #114
l2iceman's Avatar
l2iceman
So I've mounted the unit to the navi console. Like the earlier post in this thread, I used pipe hanger I found at Lowe's. I didn't need to use anything else to hold it up, as it is held in really tight, I tried sliding the unit up and down, side to side...won't budge.
Sometime this week I'm going to use cardboard to cut out two pieces to cover the space where the navi button panel would be. I'm using two because there is supposed to be two pieces(button panel and finisher), and I don't want to use a single straight piece.
My plan is to get nicely cut pieces and then wrap it with a thin foam or fabric for the leather "cushion" feel, and then wrap it in black leather. I plan to re-wire the speaker and hook it up to this cardboard piece...I'm just having trouble finding a small enough speaker cover...worst case I'll leave the speaker just behind the leather...I'm sure the sound will still be much better than having it in the unit, behing the navi console.
Attached Thumbnails Bought a Magellan 1700 GPS 7 inch screen fits in Cubby-magellan1.jpg   Bought a Magellan 1700 GPS 7 inch screen fits in Cubby-magellan2.jpg
Old Jun 13, 2013 | 07:14 AM
  #115
l2iceman's Avatar
l2iceman
Hmm, I wanted to relocate the speaker up front with a speaker grill just so that there's something there lol it seems too plain being completely blank. I guess I can always look for a small Z logo and put it there...but I figured the speaker cover would be the most subtle..I'll see how the leather-wrapped piece comes out first haha
Old Jun 14, 2013 | 10:16 AM
  #116
l2iceman's Avatar
l2iceman
seems like I'm going to have fun getting the video-in for the backup camera to work. Magellan has it's own input plug set up:
http://forums.gpsreview.net/viewtopic.php?t=21775
Apparently an old ipod video 5th gen cable will work. For those that hooked up the camera to their Magellan, what did you use? The backup camera has a single yellow video RCA out...so you must have used an adapter of some sort to get it to 3.5mm.
Old Jun 14, 2013 | 12:12 PM
  #117
kham25's Avatar
kham25
I like your ideas so far for the project.. The backup camera sounds interesting.
After so long without having a backup cam I never gave thought to adding one
Old Jun 15, 2013 | 12:42 AM
  #118
l2iceman's Avatar
l2iceman
Yea I've never had a backup camera, but for $20 shipped on ebay, figured why not since I'll have everything open and I've invested $300+ in the Magellan and navi piece.
Old Jun 15, 2013 | 07:09 AM
  #119
djwatts's Avatar
djwatts
I have an 07 z with the Magellan in place, currently where the button panel goes I left it empty. I do have the 03-05 control unit, any ideas on how to fabricate this to work?
Old Jun 16, 2013 | 04:26 AM
  #120
kham25's Avatar
kham25
Most def can't go wrong. Now your gonna make me do this MOD as well lol..
Ill tell you though you grab a lot of attention having 2 screens in the car. I get mad people eyeballing inside my car now at stop lights etc
