wiring a PAC-TR7 to AVH-P4200DVD
on
I spoke to the PAC rep about hooking up the TR7. Its set up on default video bypass programming so all I needed to do was wire it in.
I did as he said. Red => switched 12v, Black => ground, Green => remote turn-on (blue/white), and White => ebrake wire (light green).
I put in a DVD but all I got was an error saying the movie can not play while in motion (wasnt moving). The ebrake was already up when I installed the head unit. Do I have to put it down then back up to trigger the module? But that would defeat the bypass.
Anyone have any ideas?
EDIT: i'd like to upload a picture but the forum isn't allowing me...
on
I remember reading about it somewhere. Do a search in the forum, if not google it, I believe it said to ground the ebrake cable coming from the unit. However, don't believe me, do a search first.
on
Hope this helps!
on
I had the same problem on my 4100... I put in the bypass switch to where the switch panel should be on the other model cars (I have the base, didn't need the other stuff). I had to turn on and off the car a few times and toggle the switch. Eventually I got it to work. It still works, unless I disconnect the battery, then I have to do it all over again ... When I get to working on my car again this weekend, I'll try and make a youtube video of it and post it on here.
Hope this helps!
Hope this helps!
on
I'll try and hurry it up for ya. I have to do a lot of work on my car this weekend... New torque dampner, replacing my custom grounding kit, and clutch... I'll let you know when I post it. I have a partially finished DIY video of how to uninstall your stereo. If you subscribe, it'll tell you when I put up a new one. My name is the same on youtube... Hope you can toggle it!
on
I just finished wiring in the subwoofer and amp. Going to put it all together again and make sure my grounds are better and move the ebrake down to see if it now only works with the ebrake down
on
I ended up ditching the TR7 and going with the relay bypass. Cheaper and easier. I'll just return the TR7 to Amazon.
Everything is running great, except the check engine light came on and the dash kit needs to be trimmed. What a pain installing a sub and headunit at the same time.
on
on
Try resetting the car by taking off the negative battery terminal for about 30 minutes... This might solve your problem. If it continues to show up, go to an advanced auto, or autozone or what ever, and borrow their test equipment to find out what your fault code is
on
Ok so the ECU code was "a short or open circuit at the power terminal" according to Autozone. A little concern but not really. Made the trip home 4 hours.
Get home and the ECU code is gone but now the video doesn't work. Something tells me the relay bypass failed. I used a 30A relay from Autozone. Could the amperage be the issue?
I wired the relay according to: http://www.youtube.com/watch?v=g8HCcNy9QQQ
..except mine look more like attached picture.
Snowboarder, do I need to wire the grounds from the relay to its own chassis point?
EDIT: Now the sub stopped working but I figured out I was pressing the wrong button during the blue prompt screen (video works). Checking amp fuse later. This is frustrating.
on
Sorry it took so long to respond, I have had no time at all. I had to replace my clutch, engine torque damper, hoses, and fixed my parking brake bypass (re-installed, and changed position so that the underglow kit had a good contact point), as well as staying long hours at my job.
If you need more help please let me know, you can pm me, and I can hopefully give you some good advice.
on
Did you get all this fixed? It's a learning process!
350Z_Al
10-29-2020 07:44 PM
bcoffee20
11-19-2015 06:39 PM
Beater350z
09-09-2015 03:36 PM
