can you test an amp to tell if its bad?
Old May 19, 2010 | 06:44 PM
oddjobbb's Avatar
oddjobbb
Default can you test an amp to tell if its bad?
I bought a used amp online, after hooking it up it doesnt turn on. the power indicator doesnt come on. i know its getting juice .the fuse looks good also. is the amp bad?
Old May 19, 2010 | 06:47 PM
MODDEDZ's Avatar
MODDEDZ
I'd take it to an audio shop.
Old May 19, 2010 | 07:00 PM
oddjobbb's Avatar
oddjobbb
i am afraid that its the wire from the HU that tells the amp to turn on
Old May 19, 2010 | 07:35 PM
BakaN20's Avatar
BakaN20
Get a test light and see if the remote amp turn on wire is sending a signal, if you don't have a test light, try wiring it up to a relay and hear it click if it turns on. Try these to rule out the amp turn on wire. A suggest a test light, it really helps a lot for many other things. Is your amp grounded properly also?
Old May 19, 2010 | 07:38 PM
redlineTRIZLE's Avatar
redlineTRIZLE
if your worried about the remote turn on just hook a constant 12volt to both the positive and remote of the amp and see if it turns on .if not the bye bye mr amp
Old May 19, 2010 | 07:39 PM
redlineTRIZLE
*ninja edit
Old May 19, 2010 | 08:47 PM
Yes. With a signal generator and oscilloscope.
Old May 19, 2010 | 08:56 PM
oddjobbb's Avatar
oddjobbb
well i jumped the remote wire with the power wire and the amp came on so it must be the remote wire thats the problem. at least i know the amp is good.
Old May 20, 2010 | 03:24 AM
duro78's Avatar
duro78
Get yourself a dimm it could of figured it out a long time ago plus everyone should have one in their tool box there only $10
issyz
Jul 2, 2017 03:04 PM
350z82
Oct 1, 2015 06:25 PM
