Headunit without sub preamp
Old Jul 21, 2010 | 06:04 PM
tractng's Avatar
tractng
Default Headunit without sub preamp
The unit doesn't have a sub preamp.
If I used the rear as a sub, that means I lose the rear channels?
I would need to use a splitter from the front channel for the rear too?
What if I want to just power the front with an amp and use the headunit to power the rear. I won't have any problem?
http://www.crutchfield.com/s_500CDE1...ne+103bt&ssi=0
*** outputs: 4-channel preamp outputs (front, rear/sub) — rear outputs switchable to subwoofer mode with bass level control
Tnt
Old Jul 21, 2010 | 07:00 PM
tractng's Avatar
tractng
Originally Posted by bigaudiofanatic
You will use the rears for sub out and you would have to use the head units internal amp to run rears.
Or just get a better head unit.
Thats what I want to do. Have the headunit power the rear. I am just concern about the unit not producing any sound when it is switch to sub.
Tony
Old Jul 21, 2010 | 07:19 PM
walkingdead930's Avatar
walkingdead930
http://www.crutchfield.com/s_130P620...T.html?tp=5684
Old Jul 21, 2010 | 09:14 PM
It is a good question. Does using the pre-amplifier interrupt power amplifier output? I also want to know.
Old Jul 21, 2010 | 11:00 PM
tractng's Avatar
tractng
Originally Posted by walkingdead930
Meets my criteria
Old Jul 22, 2010 | 06:46 AM
MUZZY's Avatar
MUZZY
the difference in rear out and sub out is that sub out has controls on your head unit. Nothing ells. Rear out can be used as sub connections. You just do not have the capability of controlling it.
Old Jul 22, 2010 | 05:43 PM
Spike100's Avatar
Spike100
Your answer is correct.
The posts/questions after your message are mostly concerned with SubW operation (Will this H/U work with a SubW?)
As you point out, it will drive a SubW using the rear channels for this, but this H/U does not have a dedicated SubW control. Muzzy makes the same point in his reply:
I like your advice: “Or just get a better head unit.”
tractng obviously wants a H/U that provides dedicated SubW control, so he should abandon this model and look for a H/U that provides the features he wants.
--Spike
Old Jul 23, 2010 | 10:31 PM
tractng's Avatar
tractng
I just bought the unit walkingdead930 suggested (Pioneer deh-p6200bt).
I plan to do the install in small incremental. At this point, I am not sure about running the amp for the speakers, but for sure a sub. I can just pre-install the rca interconnect and remote wire (for the sub) ahead of time and just cap them off so down the road I can use them. Is this correct?
Its been a while I hook up the system.
Thanks,
tractng
jlb
Oct 15, 2017 05:10 AM
dcains
Nov 11, 2015 11:36 PM
cashmoney03
Sep 27, 2015 05:24 PM
nizl
Dec 12, 2002 02:19 PM
