Has anyone tried the OBDII Scantool by scantool.net
Old Nov 13, 2003 | 07:49 AM
chromesilverz's Avatar
chromesilverz
Default Has anyone tried the OBDII Scantool by scantool.net
Will it work in the 350z? ISO?
Can you keep them plug in constantly?
Old Nov 16, 2003 | 01:02 PM
wtsmf's Avatar
wtsmf
Yes it works. It gives the standard data back ie. RPM, speed, o2 sensor, fuel trim and error codes. It can reset your MIL light. It doesnt do the things that the Consult II does as it also interfaces with the CAN (contoller area network) of the car. This cheap enough and will allow you to check and reset codes without going to the dealer. It can stay connected to your pc as this box will keep sending the stay alive commands once it is initiated.
Old Nov 16, 2003 | 01:04 PM
wtsmf's Avatar
wtsmf
Forgot to answer the interface question. The 350z uses the ISO interface.
Old Nov 17, 2003 | 09:07 AM
andycapp's Avatar
andycapp
Did you guys build your cables or buy them? I have access to one of the OBD-II like cables that I used with the VAG-COM VW/Audi software. This one will work right (I don't have my car yet or else I'd try it....).
Old Nov 17, 2003 | 10:38 AM
wtsmf's Avatar
wtsmf
The cables came with the unit.
Old Nov 19, 2003 | 11:39 PM
wakaZ's Avatar
wakaZ
Cool...I got a Vag-Com scantool too
Will it work with Scantool?
Old Nov 19, 2003 | 11:41 PM
wakaZ's Avatar
wakaZ
Hey...I got a VagCom too...hope it works!
Don't think software would work tho
sorry, double post
Old Nov 20, 2003 | 05:47 AM
Apexi350z's Avatar
Apexi350z
Charter Member #50
will it let you reset the ecu?
Old Nov 20, 2003 | 08:41 AM
noahbuddy's Avatar
noahbuddy
I have one and am writting a java program to interface to it because... well that's what I do...
My only complaint about the scantool is the refresh rates are very slow, about 2.5 queries / second. So if you are thinking of using it as a performance tool, don't.
It's good for resetting / viewing diagnostic codes. And simple monitoring. And, it's a cool toy to have.
Old Nov 22, 2003 | 12:26 PM
ZManInNY's Avatar
ZManInNY
How much are these tools? Where can you get them? Where do you plug them into the Z? I have a laptop in my car and was thinking about doing something like this but have no clue about them whatsoever. Any help would be great. Sorry if this is a dumb question.
Old Nov 22, 2003 | 12:39 PM
wtsmf's Avatar
wtsmf
The ones above were from www.scantool.net but here is another one from www.obddiagnostics.com for $88. The software is not compatible with the others.
Old Nov 23, 2003 | 08:25 AM
Ralphus's Avatar
Ralphus
www.obd-2.com
Workshop12
Mar 23, 2020 01:45 PM
foochdawg
May 10, 2008 12:35 PM
Vivid Racing
Nov 3, 2004 06:36 AM
ChurchAutoTest
Dec 22, 2002 07:50 AM
