system upgrade
Old Aug 28, 2010 | 05:06 PM
SoCal-Zzzz's Avatar
SoCal-Zzzz
Default system upgrade
Currently have (2) Elemental Designs nine.2x amps. One powering an eD sub with 600w rms and the other powering a set of Hybrid Audio C51-2 comp speakers. I am thinking because of my current financial situation to save money I can keep the amps as is, replace my sub with a fosgate T1D210 and I was thinking of moving my front comps to my rear speakers and just running them off my kenwood HU and getting new larger 6.5" focals maybe? What do you guys think, any advice?
UPDATE: What do you guys think about used speakers. I found someone selling a set of Focal 165K2P's which usually go for around $700 for $320 shipped. He said they were used for 1 year for competition use. What do you guys think? Also they have a top depth mount of 3.03 inches, will I have any issues having those installed?
Old Aug 28, 2010 | 06:24 PM
hellsoldiers08's Avatar
hellsoldiers08
1. he used them for competition use. meaning the speakers been used and abused. I would tell him 240Max sense he turn up the sh** out of them probably. Even the 240 is alot but you not low balling him for 150 for the pair lol. Hope this part helps ya.
Old Aug 29, 2010 | 09:30 AM
Spike100's Avatar
Spike100
The Focal 165K2P's do not fit the stock door mount.
--Spike
Old Aug 29, 2010 | 02:03 PM
SoCal-Zzzz's Avatar
SoCal-Zzzz
What about the CTX65CS or CXS62 V.2. The CXS62 V.2 are almost $200 more, any advice on those two?
Old Aug 29, 2010 | 04:45 PM
Spike100's Avatar
Spike100
^^ The CTX65CS requires a mounting depth of 2.75" which is probably too deep for the stock door mount. CXS62 V.2 is even deeper, so no go.
--Spike
Old Aug 29, 2010 | 05:42 PM
SoCal-Zzzz's Avatar
SoCal-Zzzz
What about if I get a spacer like this:
https://my350z.com/forum/audio-video...-in-stock.html
I have read you can fit around 2" without spacer so does that mean with the spacer you can fit up to about a 3" speaker in the front door?
EDIT: What do you guys think between:
Focal 165 VB
Image Dynamics CXS62 V.2
Old Aug 30, 2010 | 11:10 AM
SoCal-Zzzz's Avatar
SoCal-Zzzz
bump
Old Aug 30, 2010 | 12:30 PM
Tackett's Avatar
Tackett
Dude, just get door pods from
Www.wickedcas.com
Fixes the mounting depth problem and sound much better.
Either of those components would sound great.
Have you checked out CDTs stuff? They have killer components.
Old Aug 30, 2010 | 02:00 PM
SoCal-Zzzz's Avatar
SoCal-Zzzz
I no I'm gonna get yelled at but $280 for door pods seem really really expensive :/
Old Aug 30, 2010 | 03:56 PM
Tackett's Avatar
Tackett
You'll think expensive when you hit a pothole with the windows down and those deep drivers shatter your window.
Old Aug 30, 2010 | 03:59 PM
Tackett's Avatar
Tackett
Actually, you can run either of those with a spacer. Just drill out the factory speaker grill so the sound can make it through.
There should be a decent write up around here on how to mount aftermarkets in the factory position.
You will have to use spacers with almost anything you put in there to keep the back of the driver off the window when it's rolled down.
I'll see what I can find for you.
Old Aug 30, 2010 | 05:48 PM
SoCal-Zzzz's Avatar
SoCal-Zzzz
Thanks for the input so far Tackett
Old Aug 30, 2010 | 06:39 PM
Tackett's Avatar
Tackett
NP man. Let us know how it goes.
Try this thread:
https://my350z.com/forum/audio-build...-no-56k-4.html
It's long, but check out how he did some stuff.
I'm trying to find component specific mounting threads. They are here. Just give me time.
Trying searching for "stealth" or "component spacers" and see what you get.
Old Aug 30, 2010 | 06:42 PM
Tackett's Avatar
Tackett
Also, see what the general consensus is for mounting depths. I think 2" max 3" with 1" spacer, but that's pushing it.
Old Aug 30, 2010 | 07:54 PM
SoCal-Zzzz's Avatar
SoCal-Zzzz
this is probably a stupid question, but with 1" spacers will the speaker grille and everything fit fine?
Old Aug 30, 2010 | 09:41 PM
Tackett's Avatar
Tackett
I should dude. But I'd do some hardcore measuring first. I can't say for sure. But it should.
Old Aug 31, 2010 | 02:25 PM
Spike100's Avatar
Spike100
OK, here’s the deal when installing aftermarket speakers in the 350z’s stock door mount:
  • The stock speaker grille is concave, meaning it is shaped inwards, and it is not flat.
  • A decent aftermarket speaker is deeper than the cheap stock speaker, so fitting the new speaker requires a spacer to push the speaker out enough to allow clearance for the car’s window.
  • 2.5” is the deepest speaker you can fit using a spacer with the stock door mount and the stock door grille, and that will be a tight fit.
If you want to mount a speaker with a depth > 2.5”, you will need to either cut out the stock door grill and fabricate a custom grille or use a door pod. Fabricating a custom grille is difficult since the door panel is not flat. The easiest way to do this is mounting a door pod.
--Spike
Old Aug 31, 2010 | 03:02 PM
Tackett's Avatar
Tackett
--Spike
There's your answer.
Nj spike.
sales@czp
Sep 23, 2019 03:30 PM
Justin100
Nov 29, 2015 03:58 PM
nanotech
Oct 2, 2015 05:02 AM
