Need Help Fitting Infinity Perfect 6.1 in Doors
Old Nov 27, 2003 | 09:01 AM
rezn8o2's Avatar
rezn8o2
Default Need Help Fitting Infinity Perfect 6.1 in Doors
Does anyone have the infinity perfect 6.1 installed? how did you guys get it to fit? i used the factory speakers as a spacer, but i can't fit the door panel back on because it now sticks out too much. If i try to shave the spacer then the magnet will hit the window. Any help is appreciated. Thanks.
Old Nov 27, 2003 | 01:08 PM
bastard's Avatar
bastard
You will have to cut out the little ribs around the speaker opening inside the door panel. They're white plastic, and easily taken care of with a dremel tool.
Old Nov 27, 2003 | 04:47 PM
grutter's Avatar
grutter
Exactly right...
I had to do the same to fit 6.5" JL's. I even made custom spacers because the speakers were to big to fit in the gutted factory speaker rings.
Cut the plastic ribs out of the door panel wherever they interfere.
Old Nov 27, 2003 | 07:20 PM
bastard's Avatar
bastard
On my install (JL XR 650 components), I had to build a ring of 1/4" wood to add to the spacer. This gave me the clearance around the window but necessitated the dremeling of the area around the factory grille. If you pop the grille off, you can see a spot where the speaker will hit the door panel under higher excursions. I had to dremel that part out to make it clear. Luckily, this lip won't ever show because the grille covers it nicely.
Old Nov 27, 2003 | 08:05 PM
rezn8o2's Avatar
rezn8o2
thanks for the reply guys. that was exactly what i was thinking but just wanted to know if it was done another way. also, are you guys experiencing the window hitting the speaker when you shut the doors while the window is down?
Old Nov 27, 2003 | 08:50 PM
grutter's Avatar
grutter
No interference with window at all.
Attached is pic of custom spacers I built for 6.5" JL's
Attached Thumbnails Need Help Fitting Infinity Perfect 6.1 in Doors-350z-audio-install-20.jpg
Old Nov 27, 2003 | 09:44 PM
bastard's Avatar
bastard
I have no window interference either.
Old Nov 27, 2003 | 09:53 PM
rezn8o2's Avatar
rezn8o2
hey grutter, thats a nice looking spacer. can i possibly get the specs for it. such as: thickness, type of wood, adhesive and any other details that might help.
Old Nov 27, 2003 | 10:20 PM
grutter's Avatar
grutter
It's made from two pieces of MDF. I used the factory spacer as a pattern for first piece, and cut the top piece to fit the 6.5" speakers. Glued the two halves together.
First attempt was too thick... made from two pieces of 3/4" MDF. Finished spacer (as installed on car) is 1 1/8" thick.
Attached Thumbnails Need Help Fitting Infinity Perfect 6.1 in Doors-350z-audio-install-04.jpg
Old Nov 27, 2003 | 10:21 PM
grutter's Avatar
grutter
Assembled... but too thick. Cut it down for finished spacer.
Attached Thumbnails Need Help Fitting Infinity Perfect 6.1 in Doors-350z-audio-install-06.jpg
Old Nov 28, 2003 | 09:18 AM
rezn8o2's Avatar
rezn8o2
thanks for the instructions. i think im gonna head out to home depot to get the materials and get started on it. oh, one last thing, did you just glue them together with wood glue?
Old Nov 28, 2003 | 12:05 PM
grutter's Avatar
grutter
Yup
Stevo Z
Oct 3, 2015 09:14 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
