No Bass
Old Jan 31, 2012 | 02:23 PM
jeffball610's Avatar
jeffball610
Default No Bass
I've been driving my 03 Touring for a month now, and the subwoofer stops working on occasion. I haven't pinpointed the issue yet, and was wondering if this is a common problem.
It's the stock Bose system with a Sony head unit. It seems to work fine first thing in the morning, but when it's warmer outside, the sub doesn't work at all. I would think this might be an overheating issue with the amp, but it seems odd that 75* heat would overwhelm it.
I would also think it's a bad wiring job on the head unit, but it works every morning.
Anyone have any advice on where to start looking? Is there a decent wiring diagram of the audio system on here? I'll do some more searching on here, but let me know if you have some advice.
Old Jan 31, 2012 | 03:01 PM
saywat?'s Avatar
saywat?
so how do u get it to work again? turn off car then turn it back on?
Old Jan 31, 2012 | 03:17 PM
jeffball610
No, the off/on thing won't work. Wish it was that easy.
Actually after reading more on this, there appears to be a service bulletin about this on early 2003 Touring models. (mine is a 9/02 build date)
There is a small relay that doesn't work properly. Bose and Nissan's fix is to replace the unit. I'll see if I can get this done for free. If not, then I guess I'm shopping for an amp and sub to replace the ridiculous units they put in. If you've ever seen this sub, it hardly classifies as a speaker.
I'll update my findings for other owners.
ps sorry for accidentally posting in the 370Z forum.
Old Jan 31, 2012 | 04:40 PM
Spike100's Avatar
Spike100
This is a known problem. It's a nine year-old fault and that means you won't get a free repair.
--Spike
Old Feb 13, 2012 | 05:15 AM
Derek350's Avatar
Derek350
this just happened to my 03 today, would replacing the head unit or replacing the sub fix this? if not is it an expensive relay to replace?
Old Feb 15, 2012 | 10:27 AM
Apocelypse's Avatar
Apocelypse
https://my350z.com/forum/audio-and-v...-drop-out.html
CrowzRSA
Sep 21, 2015 04:00 PM
Ryan Bonner
350Z Roadster
Sep 8, 2015 04:16 AM
Mr Fairlady
Feb 6, 2003 05:37 PM
SeattleInfo
Jan 28, 2003 01:32 PM
