2008 - ipod connections to bose x 6 cd head unit ?
Old Feb 26, 2012 | 04:41 PM
Silver DAB's Avatar
Silver DAB
Default 2008 - ipod connections to bose x 6 cd head unit ?
Hey Guys,
I've seen lots of information that the Bose head unit can accept an ipod/ iPhone adaptor cable, at the back of the head unit on the 1 x CD and/ or the tape spec.
However I've not seen any information to say this will work for my 2008 BOSE 6 x cd unit/ head.
Regardless, if I can add the USA PA11-NIS iPod interface can it be controlled via the steering wheel buttons ? Cheers, N.
Old Feb 26, 2012 | 06:39 PM
Suwaidi's Avatar
Suwaidi
https://my350z.com/forum/audio-and-v...-pa15-nis.html
It works, and can be controlled via steering wheel buttons (volume/song change).
Old Feb 27, 2012 | 10:21 AM
The Burgh's Avatar
The Burgh
Get usa pa15-infinity one, it plugs into the sat receiver in the trunk.
Old Feb 28, 2012 | 05:53 AM
nomore350Z's Avatar
nomore350Z
I have a 2008 Roadster with the Bose 6CD changer system. I do not have satellite radio (no antennae or button on radio) so my best bet for i-pod integration is the USA PA11-NIS and I will have to take apart the waterfall correct? I do have the CAT labeled button if that makes any difference.
Just want to make sure I get the right one and that there is nothing better available. I plan to eventually upgrade the entire stereo but for now I really want to use my i-Pod.
Old Mar 1, 2012 | 02:55 PM
Silver DAB's Avatar
Silver DAB
Nomore350z ..... let me know how you get on as I'm not sure there is anythng to connect the USA PA11-NIS to. I recently fitted an Ipod/ Iphone connector in my wife's Rav4 but it need an empty plug/slot in the back of the Head Unit. Ftom what I've seen so far i'm not convinced that the standard 6 x cd 'none Sat' Head Unit has that available slot. Interested to hear how you get on ...
Old Mar 2, 2012 | 01:28 PM
zakmartin's Avatar
zakmartin
I would stay away from the USA PA11-NIS. I did a write-up on it a few years ago. It's garbage. The volume from your Ipod will be halved, it's super slow and it sounds like garbled monkey crap. I went through two of them before I gave up and tore everything out. Also, Pacific Audio's customer service is the worst I've ever had the misfortune of dealing with.
The only GOOD solution: get rid of the BOSE system and start over.
Next best thing: Use a FM modulator type hook-up.
Last resort: JL Audio cleansweep + signal summing processor
I have the PA11-NIS and the cleensweep/signal summing processor rotting away in a box in my garage right now.
There's no good way out of the crappy "premium" stereo Nissan sold us with the 350Z.
Old Mar 5, 2012 | 09:59 AM
nomore350Z's Avatar
nomore350Z
Wow...I've read glowing reviews about this unit on this site. Anyone else feel the same as zakmartin?
Old Mar 8, 2012 | 07:47 PM
mr2blackna's Avatar
mr2blackna
I hate to get rid of the 6 disc cd changer. Can't believe no one has found a good solution to connect auxillary.
Old Mar 27, 2012 | 07:18 PM
Silver DAB's Avatar
Silver DAB
Default Definative answer ? 2008 ZR none sat radio 6 x cd changer.
Help,
Before I spend 2 hours pulling out the waterfall (just to find out) ... can somebody please confirm if the PA15-NIS will plug directly into my stock 2008Bose 6 x cd change - that does not have Sat Radio capability ?
thanks guys
Local radio is shi*e and I'm done with cd's following the intro of iPhone/ Spotify .....
Old Mar 29, 2012 | 08:37 PM
Suwaidi's Avatar
Suwaidi
There's a user who installed the PA15-NIS into their non-satellite unit, but it was non-bose, and they were successful. An eBay listing with compatibility states that a 350Z must have the CD/CHG button only.
http://www.ebay.com/itm/USA-SPEC-PA1...#ht_2099wt_918
The compatibility list here also confirms that it should work for your radio:
http://www.ipodcarpros.com/p203/PA15...duct_info.html
On a side note, it should take you no more than an hour (if not less) to pull the waterfall out. I just took forever since I had problems disconnecting the pod wire. In any case, you could always play it safe and call them to confirm that it should work .
Old Mar 30, 2014 | 09:43 AM
Silver DAB's Avatar
Silver DAB
Smile Bluetooth streaming & Phone working with 6 disc Bose
I finaly took the plunge and went for a Neo Bluetooth BNIS 3 V9 + Aux and USB cabels - $189.99. Local Audio shop fitted for $50 and its working great.
Bose display is limited but if you keep your phone visable you dont need it. Steering wheel controls work on volume up/down and next / previous track selection.
Old Apr 1, 2014 | 01:43 PM
nerdhiker's Avatar
nerdhiker
Where do you get the cable out? Care to share some pictures? How is the sound quality?
Stevo Z
Oct 3, 2015 09:14 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
