Installed AVH-P4300DVD
Old Mar 10, 2012 | 04:12 PM
QuintonC's Avatar
QuintonC
Default Installed AVH-P4300DVD
Got my Pioneer AVH-P4300DVD installed today, and whipped up some new custom backgrounds for it. I'm in love with this unit. Funny thing is, we ordered it off of Amazon, but originally ordered the 4100 and they messed up and gave us the 4300, win.
Here are a few pics for you all:
Old Mar 10, 2012 | 04:59 PM
StAtiXz6's Avatar
StAtiXz6
i just got rid of the 4300 for the 4400 how did you get the backgrounds on there?
Old Mar 10, 2012 | 05:00 PM
TURBOROADSTER's Avatar
TURBOROADSTER
Looks great , same HU I have .
Old Mar 10, 2012 | 05:10 PM
350Speed's Avatar
350Speed
+1. How did you get the custom backgrounds.
Thanks.
Old Mar 10, 2012 | 05:35 PM
QuintonC's Avatar
QuintonC
Very carefully 9
No, I just have a USB stick that I put the images on, and then plug it into the hu, after that you push the media button to switch from audio to images. And then find your image and push "capture" on the bottom. After that go to your background setting and look for the one that is for custom images. If you need any additional help, just ask and I can upload a video showing how to do it
Best of luck!
Old Mar 10, 2012 | 06:13 PM
beezee's Avatar
beezee
Got the same unit too. Add the pioneer HD tuner and see what a difference it makes
if you love to listen to FM. Hopefully you did not make the mistake I made at first by not connecting the Antenna blue wire. Love your background. Will try it. Will PM for help if I get lost.
After my unit, I installed the Z130BT in wife's SUV. Wished I had bought that instead though
Old Mar 10, 2012 | 07:31 PM
QuintonC's Avatar
QuintonC
Nah, I didn't get the HD Tuner, I went with XM instead. I actually had this for my Jaguar X-Type and just swapped it out when I got this car :P Just got around to getting this put in today though.
Old Mar 10, 2012 | 10:45 PM
beezee's Avatar
beezee
Did you add the Bluetooth adaptor?.
Old Mar 11, 2012 | 08:27 AM
QuintonC's Avatar
QuintonC
No, I didn't. The only add-on I have bought for this hu is the XM Tuner.
Also, here are a couple of background images if you guys are wanting them. If you want any other colors or something and want me to make them, just shoot me a PM.
Old Mar 11, 2012 | 09:08 AM
dkmesa350z's Avatar
dkmesa350z
Z emblem is upside down haha
Old Mar 11, 2012 | 09:35 AM
QuintonC's Avatar
QuintonC
Actually, it's not, just when I went to sharpen it manually, it ended up weird. It does look that way though, hmm. Thanks for pointing that out. I'll flip it :P One sec.
Edit: Fixed Thanks for pointing that out, god I feel like an idiot >.<
Old Mar 11, 2012 | 02:34 PM
beezee's Avatar
beezee
Thanks. I will try that out
Old Mar 11, 2012 | 03:20 PM
floppymoppy1234's Avatar
floppymoppy1234
hey which trim kit did you get??? i got the 42000 with the metra kit and it doesnt clear the unit when the face comes down. It keeps hitting the bottom. Any suggestions?
Old Mar 11, 2012 | 06:34 PM
BoomerZ33's Avatar
BoomerZ33
i have the same HU and i bought the Metra dash kit 99-7402. i have the same issue with mine too. it was making contact whenever the screen opened so i cut the tabs on the side but it still won't sit flush when i screw it back together.
Old Mar 11, 2012 | 07:26 PM
beezee's Avatar
beezee
I got mine to clear. The problem I have is with the shift ****. (Sorry I have AT Lol).
It hits it if it has to fully open for the SD drive unless I move to reverse or further.
Not a bother because once I loaded the SD card I have not had the need to open it.
Honestly for anyone that is ABOUT to buy this unit, I would say save up and get the AVIC Z130BT. The P4300 is an awesome unit but the Z130BT is even better.
I paid 400.00 for my unit, added HD tuner for 150. Only about 300.00 away from the
Z130 which has an awesome Navigation, built in HD tuner and bluetooth that is compatible with Android.
The bluetooth add-on for the P4300 does not have compatibility with Android. And for the iPhone 4, you always have to re-connected each time you enter your car.
The Z130BT has the most current software.
Another thing about the Z130BT is the RCA connections. They are part of the Harness.
If you install it in the Z, you get more room behind the Unit.
Old Mar 12, 2012 | 06:37 PM
QuintonC's Avatar
QuintonC
Used the metra kit and modified the mounting holes and moved the unit backwards. If you use the kit stock, with the stock brackets, it will catch. Hope that helped!
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
