rear view camera interrupt
Old May 28, 2012 | 01:35 PM
giters117's Avatar
giters117
Default rear view camera interrupt
so i just put in a kenwood ddx319 head unit (http://www.kenwoodusa.com/Car_Entert...e_Video/DDX319) and i love it so far.
i also picked up a super cheap rear view camera since the ddx had the input for it (http://koolertron.amazonwebstore.com...B0049LBJ56.htm)
i tapped into the lt green reverse wire to give the camera power, and also set the rear cam interrupt to "on" in the headunits setting...
i shift into reverse and nothing happens, i have to press the button to pull up the display
just wondering if this type of thing has happened to anyone else before and what can be done..
thanks in advance
TL:DR rear camera interrupt option on my headunit doesnt make it so the camera switches on automatically
Old May 28, 2012 | 02:11 PM
R350Zz33's Avatar
R350Zz33
u also have to hook up the decks reverse thing to the same wire
Old May 28, 2012 | 03:34 PM
giters117's Avatar
giters117
thank you, i guess i have to get some wire to run from the headunit to the reverse light wire where the camera gets its power from, think thats good? (this it the first headunit/car audio i have ever done, still trying to figure it all out)
thanks again
Old May 28, 2012 | 04:34 PM
R350Zz33's Avatar
R350Zz33
thats what i did
Old May 28, 2012 | 07:44 PM
PDX_Racer's Avatar
PDX_Racer
Originally Posted by R350Zz33
thats what i did
Where did you pick up the line in your installation? I see that there is a wire that goes from the passenger side to the driver side and then back to the rear of the car, but appears to be buried pretty deep in the dash.
Old May 28, 2012 | 07:45 PM
beezee's Avatar
beezee
Exactly what op said. The reverse signal wire from the back of the headunit only signals your headunit to switch to the reverse camera mode. The light green line you tapped into is good for that. But in addition to that your reverse camera itself needs power.
Old May 28, 2012 | 09:15 PM
R350Zz33's Avatar
R350Zz33
i took it right from the + lead on the reverse bulb plug
Old Jun 5, 2012 | 05:34 PM
giters117's Avatar
giters117
so i got the interrupt hooked up to the rear light and also ran a wire from the camera to the headunit power so i can have the camera on whenever the headunit is on
all is as i wanted, thanks for the help guys
Tochigi_236
Sep 27, 2015 03:40 PM
