Aftermarket radio issues! please help.
Old Sep 14, 2012 | 07:39 AM
lagatbezan's Avatar
lagatbezan
Default Aftermarket radio issues! please help.
hi all, i installed a Pioneer 940BT in my 07 350z bose and everything is working great except there is some feedback noise coming from the speakers at low volume. Also when i turn the radio off, the noise increases and then decreases and goes away! it does that also when i change sources on the radio. I used the metra harness with the RCA jacks which is the one for the vehicle. any suggestions?
Old Sep 14, 2012 | 08:17 AM
JohnG202's Avatar
JohnG202
Double check your grounds. Sounds like you have a bad one
Old Sep 14, 2012 | 09:26 AM
lagatbezan's Avatar
lagatbezan
i checked all my grounds and they all seem good. I even gave it a ground with my powerprobe and still the same things. I have done so many radio installations and never had an issue like this. its as if the factory amp doesnt shut off when the radio is powered off! there is a little of hissing noise even when the radio is off.
Old Sep 14, 2012 | 09:05 PM
bender's Avatar
bender
If you're retaining the stock Bose amp, it's recommended you use the PAC ROEM-NIS2 module in between your new headunit and the existing harness. Your symptoms are similar to those who went the same route as yourself (eg. noise at low volumes)
Old Sep 16, 2012 | 01:36 PM
coanan's Avatar
coanan
try grounding one of the RCAs connected to the head unit (outer ring of RCA) to the head unit chassis.
Some amps power down slow after the headunit is turned off; watch the power light on your amps, you'll see.
Old Sep 16, 2012 | 04:07 PM
beezee's Avatar
beezee
This is your solution. Try that and your problem would be solved
Old Oct 5, 2012 | 07:31 AM
lagatbezan's Avatar
lagatbezan
I just reinstalled it all with the PAC ROEM-NIS2 and its still doing the same thing! the noise is so weird! when i lower the volume, there is this feedback that comes in, gets louder and then goes away! a wave of feedback! it goes away until i change the volume or change the source and then does the same thing. i even tried another radio but it also did the same! any other suggestions?
Old Oct 5, 2012 | 07:36 AM
Z_on_TE37's's Avatar
Z_on_TE37's
I've been in audio for a while now. Sounds to me that you need to run your power wire further away from your RCA and remote wire. I know ppl who have aftermarket stuff and that's usually the solution.
Old Oct 5, 2012 | 07:42 AM
lagatbezan's Avatar
lagatbezan
there are no aftermarket power wires ran in the car. using the plug and play harness to install the radio.
apex locator
Jul 23, 2021 02:27 AM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
350z82
Oct 1, 2015 06:25 PM
SharX59
Sep 27, 2015 09:23 AM
