USB HDD And Flash Drives???
Everyone tells me that my 300gb hdd wont be able to connect/read to the head unit ill be installing tomorrow. But none of them can tell me why. do any of you know? And if i cant it seems most flash drives do connect without a problem, but say for example if it exceeds past a certain amount of gb will it reject it like it apparently does with the HDD? in case you need specs its a Western digital passport 300gb
thanks for your time and i appreciate any help you guys can give me
also if this thread is already covered im sorry!
Is it a question of the file allocation table? I had a similar issue plugging a 250 gig hard drive in my Ford F150 with Sync. I had to format the hard drive FAT32 vice NTFS and it had no issues reading the contents. Makes for a great road trip mix when you have 20,000+ songs on tap.
Don't know. I just recall that with my Kenwood DDX516 there is a limit to the size of the disk the unit will access, as well as the number of subdirectory levels it can read. I've got a newer DDX470, and that manual states it will read both FAT 16 and 32 disks, but doesn't mention anything more specific. The only thing I ever used the USB input for was an 8gb flash rive containing jpgs to use as background screens to replace the ones included with the unit.
I'm a Mac-user, but of you use a PC, it's going to be about the same. Use your disk utility program to format the disk however you choose. There should be multiple options to pick from, and.or you can probably download some free utility to use if Windows won;t do what you want.
350Z_Al
Oct 29, 2020 07:44 PM
