No Cutting-Which Screen?
Old Jan 30, 2004 | 04:58 PM
Dre Dizzle's Avatar
Dre Dizzle
Question No Cutting-Which Screen?
I have a 2004 base model with no navi and would like a screen to fit in the exact compartment. I've heard of others having to get things cut and what not, but I don't want that. Does any screen fit in the compartment perfectly? Thanks in advance.
Old Feb 1, 2004 | 10:50 PM
hybridart's Avatar
hybridart
yeah the farenheit 7001 - 7" lcd screen fits perfectly. well it does in the 2003 models. i dunno about 2004.
Old Feb 5, 2004 | 07:38 PM
Losing Grip's Avatar
Losing Grip
will any 7" screen fit?
john
Old Feb 5, 2004 | 07:58 PM
ares's Avatar
ares
Veteran
I know the xenarc requires some modification, namely, removing the case.
Old Feb 6, 2004 | 09:47 AM
SangWL's Avatar
SangWL
Default get alpine
the exact model is the TME-760.
sang
Old Feb 6, 2004 | 10:14 AM
DMD's Avatar
DMD
Default Re: get alpine
[QUOTE]Originally posted by SangWL
[B]the exact model is the TME-760.
What GPS software is that....../?
I know the lilliput fits perfect, but you must remove the case...Did it my '03 just posted some pics under
https://my350z.com/forum/showthread....threadid=59808
Old Feb 8, 2004 | 05:44 PM
Losing Grip
is it hard to remove that case?
-john
Old Feb 8, 2004 | 05:53 PM
DMD's Avatar
DMD
-john
If you can use a screwdriver you can open the case!
Old Feb 9, 2004 | 03:57 PM
Norel350Z's Avatar
Norel350Z
the 04 door doesn't retract like the 03, having said that keep in mind that the door itself may be thicker on the 04 then on the 03, so when it is closed it may hit the screen.. id don't know just a thought.
Old Feb 11, 2004 | 07:00 AM
fresno350's Avatar
fresno350
dude, just get the farenhiet 7001. it mounts from the back, no cutting required. i fits perfect. BUT.....if you want to make sure you see the infra-red eye on the screen you might want to cut a small notch out of the border of your nav bin. you will see what im talking about when you get the screen. its easy, i did it
Old Feb 11, 2004 | 07:24 AM
DMD's Avatar
DMD
Does the farenheit screen accept a VGA connection or do I have to use a video out?
Old Feb 12, 2004 | 03:50 AM
LS350Z's Avatar
LS350Z
Charter Member #56
He's correct, the 7001 fits perfect with the only thing you have to do is drill one small hole for the remote eye. I installed one on an 03 Z and was amazed at how well it fit.
Old Feb 12, 2004 | 07:27 AM
supirio's Avatar
supirio
Default 7001
Can't you set up the Farenheit 7001 so that it turns on when the screen receives a video feed? Like an automatic turn on feature? Some farenheit screens have it, I forget how my friend has his setup I'll have to ask him
Workshop12
Mar 23, 2020 01:45 PM
jlb
Oct 15, 2017 05:10 AM
Tochigi_236
Sep 27, 2015 03:40 PM
alphared
Nov 14, 2002 12:43 AM
InternetABYSS
Jul 17, 2002 07:07 PM
