BOSE system weight?
Old Mar 10, 2014 | 12:08 PM
SIR_pierre's Avatar
SIR_pierre
Default BOSE system weight?
Is there anyone that have removed their BOSE stereo and weight it?
Or have it laying around and can weight it?
The whole thing, player, speakers, amp, subwoofer.
Old Mar 10, 2014 | 01:07 PM
beezee's Avatar
beezee
Can you give a reason for this? That can convince me to go through that hussle.
I pulled mine out.
Old Mar 10, 2014 | 01:31 PM
92K1500's Avatar
92K1500
If I can find my mids/highs amp I will weigh it all for you. I'm missing a tweeter so I'll ballpark it. Tweeters are light.
Old Mar 10, 2014 | 01:58 PM
SIR_pierre's Avatar
SIR_pierre
Thanks =)
The whole point is to see how light i can get a mutch better system for.
A good but light soundsystem to have in a racecar =)
So i wanted to know what goal i have to make / the OEM system weight
Old Mar 10, 2014 | 02:49 PM
bender's Avatar
bender
You'd be better off squeezing a turd into the bowl before you drive. Swapping out a bose system for any other aftermarket system isn't going to save you squat. The Bose speakers are practically made out of cardboard.
Anyways, all the speakers, brackets, and amps weight 16 pounds.
Head unit weighs 8.
24 pounds total.
Old Mar 10, 2014 | 04:09 PM
Spike100's Avatar
Spike100
Pierre... Your premise is faulty.
One reason the Bose in the Z sounds poorly is that the components a light weight (no pun intended). You will more than double the weight by replacing with components providing decent sound.
You might want to rethink this.
--Spike
Old Mar 10, 2014 | 04:23 PM
SIR_pierre's Avatar
SIR_pierre
Head unit weighs 8.
24 pounds total.
Really? No more? i read 100lbs here on the Forum.
Old Mar 10, 2014 | 04:38 PM
Spike100's Avatar
Spike100
^^ 24 pounds is accurate.
H/U: 7 lbs
Front speakers (2): 2 lbs
Rear speakers (2): 2 lbs
SubW (1): 5 lbs
Amps (external and SubW): 5 lbs
Wiring and Connections: 3 lbs
A similar replacement with good components can easily be 2 to 3x’s this weight.
I think you should just keep your OEM Bose installation.
--Spike
Old Mar 10, 2014 | 04:43 PM
SIR_pierre's Avatar
SIR_pierre
H/U: 7 lbs
SubW (1): 5 lbs
--Spike
Thank you very mutch for that. A perfect answer..
What the hell is this guy talking about then?!
http://www.chrishammond.com/cars/350...on-a-diet.aspx
Old Mar 10, 2014 | 04:48 PM
Spike100's Avatar
Spike100
^^ Does he not say: "When I purchased the car in January of 2010 I knew a few things. The stereo in the car was aftermarket, and so were the two 10” subs in the back of the car.”
Wasn’t your question:
How is your question related to the post you reference?
--Spike
Old Mar 10, 2014 | 04:53 PM
SIR_pierre's Avatar
SIR_pierre
--Spike
Oh sorry wrong link, Im on my iphone.
There was a thread here on the forum where he said it weight 100lbs. But it was most likely the same thing there.. He was talking about an aftermarket stereo.
My main problem is just that the BOSE player wont work becuse my car is so stiff.
CD player is useless.. The speakers is kind of ok.
Old Mar 10, 2014 | 05:15 PM
Spike100's Avatar
Spike100
^^ I assume you have the OEM Bose system in your 350z. That system is designed as an inexpensive light weight CES not meant for people looking for middle to high-end sound.
If you primarily track your car, you probably do not want the weight you add with a better audio system.
You need to make a decision here. The tradeoff is better sound that costs more weight.
--Spike
Old Mar 10, 2014 | 07:48 PM
SIR_pierre's Avatar
SIR_pierre
Yeah... I thought i could get both lighter and better sound... I see now how stupid that was
Thanks For The answers
Old Mar 11, 2014 | 06:20 AM
bender's Avatar
bender
The Bose headunit won't work because it's junk, not because "your car is stiff". A good majority of people here have had their factory head unit crap out on them. Whether it's the cd player skipping, not playing at all, or whatever it is, it's not a vehicle specific issue.
If the sound is OK for you as is, just swap out the headunit. You can improve the sound quite a bit just by swapping it out. It wont be as nice as a complete aftermarket system, but if the sound is OK for you now, you may be surprised the difference a quality headunit will make.
Old Mar 11, 2014 | 06:39 AM
SIR_pierre's Avatar
SIR_pierre
Yeah.. As ong as i can play something.. Something with a USB port would be great.
Does anything worj with the BOSE system?
I can remember that some of the guys (here in sweden) had problem with getting the BOSE amp to work with another brand player
Old Mar 11, 2014 | 07:15 AM
bender's Avatar
bender
Connect a Pac Roem NIS2 in between the harness and the head unit and you'll be able to use any head unit on the market problem free.
sales@czp
Sep 23, 2019 03:30 PM
Justin100
Nov 29, 2015 03:58 PM
nanotech
Oct 2, 2015 05:02 AM
