HELP! Double din radio install (touchscreen)
Old Jan 7, 2020 | 06:42 PM
Zena8956's Avatar
Zena8956
Default HELP! Double din radio install (touchscreen)
I am a noob in need of help! Never installed a radio before. I am pretty sure I just connect the right colors from the harness to the stereo. But there is this random black cord on the left that I do not know what to do with. Someone please help, it would be much appreciated
Old Jan 7, 2020 | 06:53 PM
813_350Z's Avatar
813_350Z
Your radio's manual should tell you which color does what. Print a copy of the wiring color diagram for your year 350z and just match them up.
Does that black cable have a ring terminal on it?
Old Jan 7, 2020 | 07:54 PM
dkmura's Avatar
dkmura
General & DIY Moderator
Or is the black cable simply the antenna?
Old Jan 7, 2020 | 08:09 PM
813_350Z's Avatar
813_350Z
The silver plug/cable to the right of the right-most connector is the antenna. I believe he is referring to the black wire on the far left. Positive it is a groind wire for something.
Old Jan 8, 2020 | 03:24 AM
Heel Til I Die's Avatar
Heel Til I Die
The black wire doesn't appear to be coming from the oem stereo harness. My guess is that it's a ground wire for some other aftermarket accessory. Also, based on the fact that the end is frayed, it was probably grounded next to the mounting screw tab where it's laying in your pic.
Old Jan 8, 2020 | 09:58 AM
Zena8956's Avatar
Zena8956
Thanks guys
Old Jan 8, 2020 | 04:13 PM
Spike100's Avatar
Spike100
There does seem to be some standards in automobile wiring:
  • Black is a ground wire
  • Red is an ignition controlled power wire
  • Yellow is a non-ignition controlled (constant) power wire
There are other color constants that our contributors/readers here can comment about or provide information.
Old Jan 14, 2020 | 12:17 PM
MacksZs's Avatar
MacksZs
It's best to check with the install instructions for your specific radio. Here's some common color vs function combo.
- Purple and Purple/Black - speaker wires
- Green and Green/Black = speaker wires
- White and White/Black = speaker wires
- Gray and Gray/Black = speaker wires
- Blue = remote power on. (turn on for an amp, power antenna, etc.)
- Blue/White = remote turn on
- Orange = illumination (works with dimming/brightening your interior lights)
- Brown = speed sensing (change volume with speed)
Hope this helps.
Old Jan 14, 2020 | 05:45 PM
Spike100's Avatar
Spike100
Originally Posted by MacksZs
It's best to check with the install instructions for your specific radio. […].
Of course... There will always be variations, but hopefully manufacturers follow industry standards/constants. Notice that the black wire is a ground for the radio, but also a ground for speakers. Black is typically a ground for "whatever."
Teha99
Feb 26, 2012 12:46 PM
tree_fitty
Mar 23, 2009 12:16 PM
rtiid22
Jan 13, 2009 05:06 AM
kevinkatz
Jul 13, 2006 06:48 PM
netman_one
350Z Roadster
Jun 3, 2005 07:00 PM
