Attention: Those With Screens!
Old May 26, 2004 | 06:45 PM
Dre Dizzle's Avatar
Dre Dizzle
Default Attention: Those With Screens!
Where are you getting ur sound from? I'm going to be buying a screen to run with my PS2 in the car. The problem is my head unit, Sony WX 4500X, doesn't have an aux. input. Should I just get a new head unit with aux. input, or will I be satisfied with the sound from an FM modulator? Is the difference significant enough to warrant a new head unit purchase?
Thanks in advance!
Old May 28, 2004 | 11:22 AM
Dre Dizzle's Avatar
Dre Dizzle
bump. Anyone out there?
Old May 28, 2004 | 12:22 PM
BoostTed's Avatar
BoostTed
ive used an FM modulator in the past and now using a AUX input. For me atleast the difference in sound quality is quite significant, but then again Im picky in the sound quality department. Was teh sound coming from the FMO modulator bad..no but it sure wasnt as good as the direct Aux input. If u are ever in LA or OC during the weekends hit me up and i'll let u listen to it.
Old May 28, 2004 | 04:06 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
I actually have two FM modulators. One for my In-car PC and the other for my XM radio. Both sound just fine to me.
Old May 28, 2004 | 04:39 PM
ares's Avatar
ares
Veteran
I couldnt use an FM modulator, no free stations on the entire range.
how are you guys doing it?
Old May 28, 2004 | 05:17 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
One is on 89.7 and the other is on 87.9 or something like that.
Old May 29, 2004 | 06:16 PM
thunder0880's Avatar
thunder0880
I have a audiobahn 7" screen used to play with my ps2. The fm mod puts out great sound and no problems as of yet.
Old May 31, 2004 | 09:25 PM
BoostTed's Avatar
BoostTed
are u running a on/off switch for the fm modulator? if no then the FM modulator is on all the time and might be why u have no free stattions on the entire range, if i read your problem correctly.
Old May 31, 2004 | 10:46 PM
gringott's Avatar
gringott
Default Get the XA-300
Adds 2 aux inputs and a usb input to sony head units using the changer net. I got one and it really rocks.
Old Jun 1, 2004 | 06:18 AM
leemik's Avatar
leemik
I'm using an FM modulator with autosensing (JVC model)... It turns on if it detects a signal.. The bad part is when it's quiet for more than 10 seconds or so, it turns off.. I just wish I could turn that timeframe up a little higher because every once in a while it does the wrong thing..
--mike
Old Jun 1, 2004 | 06:22 AM
dmazyn's Avatar
dmazyn
My eclispe head unit has an aux port which I just took a cable from the output of the computer to the imput of the head unit. All I have to do it put the head unit on the Aux imput and all is good.
Workshop12
Mar 23, 2020 01:45 PM
jlb
Oct 15, 2017 05:10 AM
Tochigi_236
Sep 27, 2015 03:40 PM
alphared
Nov 14, 2002 12:43 AM
InternetABYSS
Jul 17, 2002 07:07 PM
