Radio Install - Harness Question
Old Jun 16, 2004 | 10:35 AM
ousig's Avatar
ousig
Default Radio Install - Harness Question
I am going to be installing my new head unit (alpine 9835) in a few days and I have a couple questions about connecting the wiring harnesses.
1. Illumination/dimmer wires - The factory harnes has two wires for this a positive and a negative. The alpine harness only has one wire. Which wire (+ or -) goes into the alpine harness and do I need to connect the other one? If so where?
2. Radio antenna amp - Is the power antenna the only wire that the car uses or do I also need to connect the remote turn on wire to the factory harness?
3. Ground - Is there a good place to ground the amp behind the dash or is it ok to use the ground on the factory wiring harness?
Thank you for help.
Old Jun 16, 2004 | 11:16 AM
bastard's Avatar
bastard
1.) I don't remember which illumination/dimmer wire I used. I can only suggest trying both to see which works.
2.) You must connect the power antenna or amplifier remote turn-on wire to the stock harness' power antenna lead. If you do not, your reception will be horrible. My headunit (Pioneer 9400) did not have a power antenna lead, so I used the remote. The antenna amplifier is located near the antenna, underneath that weird fuzzy panel between the strut tower bar and the rear of the car, on the driver's side.
3.) Can't remember where I grounded either, but I imagine there's a bolt within easy reach near the shifter that'll work fine. Another possibility is one of the bolts holding some of the computer crap down underneath the console.
Old Jun 16, 2004 | 12:52 PM
ecstaz's Avatar
ecstaz
A great place to ground the head unit is up where the harness that goes to the top gauges is. You will be able to see other wires grounded under a bolt there.
Old Jun 17, 2004 | 10:00 AM
ousig's Avatar
ousig
Thanks
I am going to install this either later today or tomorrow.
Old Jun 17, 2004 | 01:18 PM
cehome's Avatar
cehome
What's wrong with hooking up the ground to the wire harness?
Old Jun 17, 2004 | 01:43 PM
Zrated's Avatar
Zrated
Did you get the adaptor harness so you don't have to cut up you factory one?
If so, When you plug the adaptor harness into the factory harness there is only one orange wire for illumination to connect to the Alpine harness.
For Radio amp I tapped into the 12V switched power (Red) in adaptor harness.
For ground I use the metal bracing that the console bolts to. I believe I put the 2 grounds under the two screws that are on the outer sides of the white box that the temp/fan/ac controller plugs into.
I have 0 noise.
Old Jun 17, 2004 | 06:57 PM
ousig's Avatar
ousig
Three hours later I am finished.
For future installers
1. Positive wire for the dimmer
2. Power antenna wire only (thanks bastard)
3. There are two bolts behind the triple guage cluster that you can use to ground the radio. (thanks ecstaz)
Old Jun 17, 2004 | 07:02 PM
ousig's Avatar
ousig
I did use the harness to avoid cutting the factory one.
For the radio amp I ran a 12g wire directly to the battery.
Old Jun 18, 2004 | 07:59 AM
silverstoneTT's Avatar
silverstoneTT
looks nice
m_0g
Jun 3, 2021 10:05 AM
dboyzalter
North East Marketplace
15
May 6, 2018 09:41 AM
BEBO'S ZEE
Jun 7, 2016 07:48 AM
Vigman
Nov 17, 2015 04:34 AM
Sailors350Z
Sep 25, 2015 08:21 AM
