My Sub install .... VERSION 2 ....
Old Jun 28, 2004 | 07:43 PM
350trackz's Avatar
350trackz
Default My Sub install .... VERSION 2 ....
Got done with the boxes today ... trying to decide if I should keep the amps where they are or put them behind the seats ... grills will be in in a couple of days ... any and all comments are welcome !!!
REAR VIEW
Old Jun 28, 2004 | 07:44 PM
350trackz's Avatar
350trackz
SIDE VIEW 1
Old Jun 28, 2004 | 07:45 PM
350trackz's Avatar
350trackz
SIDE VIEW 2
Old Jun 28, 2004 | 08:14 PM
D@ActiveTuning's Avatar
D@ActiveTuning
Looks good, very clean! And allows you to still use almost all your space in the trunk!
Old Jun 28, 2004 | 08:25 PM
zand02max's Avatar
zand02max
Originally posted by 350trackz
SIDE VIEW 2
Nice install, I wonder if they can make 12's fit there and still use the trunk for the spare tire?
Old Jun 28, 2004 | 08:44 PM
350trackz's Avatar
350trackz
My boxes will fit 12's, just depends on which ones ... 12w3v2 will fit with a little extra mounting surface height.
Old Jun 28, 2004 | 08:59 PM
stu46's Avatar
stu46
It depends if you want do display the amps or not. Do you use your trunk space a lot? I would leave it how it is.
As far as 10s or 12s, you can fit either 10s ported or 12s sealed in about the same air space. The ported box will be a lot louder than the sealed. However, the sealed will be a lot cleaner. It just depends on what you listen to and how you like your bass.
Old Jun 28, 2004 | 10:26 PM
HaNkYs_Z's Avatar
HaNkYs_Z
350trackz, where did you get your parts and systems done at ? and how much? pm me with the detail if you can, thanks
Old Jun 29, 2004 | 12:08 PM
roydiculous's Avatar
roydiculous
that is a damn sweet install. Are you using fiberglass for those enclosures or just particleboard (or whatever it's called)
Old Jun 29, 2004 | 12:09 PM
350trackz's Avatar
350trackz
fiberglass with mdf fronts
Old Jun 30, 2004 | 01:46 AM
Z8M's Avatar
Z8M
Very nice set-up. I've always liked the subs positioned in each corner of the trunk, very efficient use of space. Where did you get your sub enclosures done? I'd like to get one for my Z as well.
Old Jun 30, 2004 | 05:35 AM
kitkos's Avatar
kitkos
I love this install.
Details?
DYI or shop?
Where? How much?
Old Jun 30, 2004 | 06:47 AM
350trackz's Avatar
350trackz
The amp rack I did myself back in the day when my subs were behind the seats.
I wish I could have made these myself !!! I had never used fiberglass before, so I paid ... and watched (local shop in Plano - Car Toys). Builder had been doing fiberglass for a long time (10+ years).
Costs involved:
Amp Box (3/4" MDF) - $100 or so in parts ... made a while ago, but $100 should cover the costs
Sub Boxes - I paid $500 (labor) and $60 (supplies) for the pair of them, I supplied the carpet so it would match what I already used. Snug fit and look pretty cool. Took the shop 12 hours to make them .. a solid day.
Old Jul 1, 2004 | 07:12 AM
motown's Avatar
motown
Diggin the install! That's a great idea. Personally, the only reason I'd move the amps to the space behind the seats is if you want to put your spare back in. Otherwise, this looks great. Regards to displaying them back there, there are plenty of ways to make that look good. That's where I'm mounting my amps and I plan to make them 'displayable'. Also, if you're currently having any problems with amps overheating, they might get better ventilation back there, depending on your set-up. That's a pretty cavernous space behind the seats, easy to get good cooling if done properly. Good luck! Again, love those boxes, they look great!
Old Jul 2, 2004 | 12:51 PM
React3's Avatar
React3
Nice clean setup... Good Luck with that.
Old Jul 2, 2004 | 05:47 PM
Reggi914's Avatar
Reggi914
super clean, very nice!
Fixxxercask
Nov 9, 2015 11:10 AM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
