Alpine TME-M770 Moniter
Old Aug 16, 2004 | 07:37 PM
nroman's Avatar
nroman
Default Alpine TME-M770 Moniter
I was wondering if anyone has installed the Alpine TME-M 770 touch screen yet. I just ordered it and am worried about the fit of it. I also ordered a 2003 cubby hole, so that might help.
Old Aug 16, 2004 | 08:35 PM
SangWL's Avatar
SangWL
Default Re: Alpine TME-M770 Moniter
if its the same size as my tme-760 then no worries what so ever.
mine fit fine.
sang
Old Aug 16, 2004 | 10:41 PM
HaNkYs_Z's Avatar
HaNkYs_Z
Sang, post some pictures!
where did you guys buy the screen from? how's the fitment? and how much did you guys pay? where is the best place to get them?
Old Aug 17, 2004 | 04:03 AM
nroman's Avatar
nroman
Default Not the same size
It is not the exact same size at the M760. It is wide screen and has no buttons on the side of it, being that it is touch screen. I get it today, so I will post some pics of it.
Old Aug 17, 2004 | 10:34 AM
SangWL's Avatar
SangWL
Default Re: Not the same size
i know what you cha mean, but cause it has no buttons the overall length and height might be similar.
if it is, then you should be fine,
hank check out my site to see the pics.
sang
Old Aug 17, 2004 | 03:06 PM
HaNkYs_Z's Avatar
HaNkYs_Z
Sang! you link doesn't work bro!!
Old Aug 18, 2004 | 03:00 AM
jreiter's Avatar
jreiter
I did a 2003 cubby hole retrofit in my 2004 Z, and the TME-M760 fits perfectly. You only have to trim a little of the right side away to clear the buttons. Here is a pic of my 760 install in a 2003 cubby hole so you can see the trimming and fitment:
http://www.spintronic.com/gallery/vi...eadunit_screen
The 770 has no buttons on the side, and thus it is a bit narrower. You can see the specs right on Alpine's website. The 770 is 16 mm narrower than the 760. This would suggest to me that you won't have to do *any* trimming of the 2003 cubby hole unit.
Old Aug 18, 2004 | 09:23 AM
SangWL's Avatar
SangWL
wierd, i didn't have to trim at all, hmmmmm
anyways sounds like the 770 would fit fine.
Old Aug 18, 2004 | 01:09 PM
jreiter's Avatar
jreiter
You fit a 760 in the 2003 cubby hole with no trimming to allow for the buttons? That is weird. If you look at mine, the left side of the screen is at the very edge of the hole, and trimming had to be done to fit the buttons on the right. I can't imagine how you could get away with no trimming. (?) Any chance you might have some pics online? (You're link in your sig doesn't seem to work.)
Old Aug 18, 2004 | 04:32 PM
SangWL's Avatar
SangWL
i'll post pics once i get back from vacation, i'll be back the 23rd,
sang
Old Aug 22, 2004 | 12:07 PM
SangWL's Avatar
SangWL
here are the pics i promised, as you can see, no moderations were done, the screen fit fine.
sang
Old Aug 22, 2004 | 06:06 PM
jreiter's Avatar
jreiter
sang
That's wacky. Check mine out. You can see how the edges of my pocket come in just a little bit more than your's do, thus the small bit of trimming we had to do. Weird!
Old Aug 22, 2004 | 07:30 PM
SangWL's Avatar
SangWL
[QUOTE]Originally posted by jreiter
[B]That's wacky. Check mine out. You can see how the edges of my pocket come in just a little bit more than your's do, thus the small bit of trimming we had to do. Weird!
just noticed, should have before, yours is a 2004.
i think thats why.
lol
sang
Old Aug 22, 2004 | 10:12 PM
jreiter's Avatar
jreiter
i think thats why.
lol
sang
Not quite. My car is a 2004, but the 2004 cubby holes were totally different and much smaller. Much smaller pocket, and the doors simply hinged up and did not slide in. So (as I mentioned in my first post up above) I retrofitted a 2003 cubby hole in there since they are much larger and hold aftermarket screens much better.
It's possible that, due to the complaints customers initially had about the 2003 cubby holes (mainly the flimsy door assembly), Nissan slightly redesigned the 2003 part. One of the side effects could've been a slightly less wide hole.
Anyway, it sounds like folks with a stock 2003 car probably won't need trimming, but folks who do the 2003 retrofit (using new parts, not something obtained from a junk yard) might need a bit of trimming. Regardless, the trimming is minor. As you can see, we simply carved out a small bit. Not a big deal at all.
Old Aug 23, 2004 | 05:24 AM
SangWL's Avatar
SangWL
true true
sang
dcains
Nov 11, 2015 11:36 PM
Ryan Bonner
350Z Roadster
Sep 8, 2015 04:16 AM
toothlessracer
Mar 15, 2003 09:06 AM
topeewala
Dec 11, 2002 01:48 PM
Namagomi
Nov 10, 2002 08:31 PM
