Help with Sirius Antenna Install
Old Aug 31, 2004 | 05:20 PM
Frisco's Avatar
Frisco
Default Help with Sirius Antenna Install
Well i finally got my windows tinted and it turns out they're metallic so I can't leave it mounted on my strut brace. Now I've got to put it on the roof. How has anyone been able to run the wire through the hatch?
Old Sep 1, 2004 | 05:19 PM
Frisco's Avatar
Frisco
C'mon I know someone has done this.....
Old Sep 1, 2004 | 06:07 PM
swoobyz's Avatar
swoobyz
Do it up front!
Pv
Old Sep 1, 2004 | 09:33 PM
Frisco's Avatar
Frisco
I'm trying to avoid from having to rip everything out again.
Old Sep 2, 2004 | 06:29 AM
2003z's Avatar
2003z
shave the rear wiper, or at least the rear wiper washer and put it there:
Old Sep 2, 2004 | 06:49 AM
Frisco's Avatar
Frisco
It looks like you just cut the entire thing off there, is that right? How do you keep water from running under there and is there enough metal there for the magnet to hold it?
Old Sep 2, 2004 | 06:58 AM
2003z's Avatar
2003z
I cut the pigtail off and used black silicone to seal the edges. The antenna is held on with double sided tape, which was supplied with it. Even if water were to leak under it though, it wouldn't be a problem, as the underside of that hole is between the roof and rear hatch area, where water would just drain down the sides, as it does when rolling off the back of the roof.
Old Sep 4, 2004 | 07:09 AM
Mooseknuckles's Avatar
Mooseknuckles
I would **** my self If I saw my dash ripped apart like that!
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
