Popping noise from speakers
Old Sep 15, 2004 | 03:35 PM
sal1's Avatar
sal1
Default Popping noise from speakers
Stero experts. What's the fix?? When I turn my system off, either with the on/off switch or when I shut the car off, the speakers pop. I appreciate your inputs.
Old Sep 15, 2004 | 10:09 PM
Ahsmo's Avatar
Ahsmo
Imakecopies
Are you wired into stock HU or aftermarket?
Old Sep 16, 2004 | 12:29 PM
the7ferret's Avatar
the7ferret
You got it hooked up to an amp I presume. That is normal, its just the amp, headunit, and everything turning on at the same time and energy surging though the speakers, some headunits have a setup for a delayed amp start and stop. If yours has that set it to a couple seconds and it will go away.
Old Sep 16, 2004 | 05:45 PM
Ahsmo's Avatar
Ahsmo
Imakecopies
no that is not normal lol
If it is wired correctly then they should not pop... give us some more info on your system
Old Sep 16, 2004 | 07:42 PM
sal1's Avatar
sal1
I have a Clarion VRX935VD (am/fm/dvd/sirus/7"lcd screen, hooked up to two amps, one drives the sub and the other drives the speakers. I believe the popping sound comes jud=st from the rear speakers. I don't believe this HU has a delay amp start up and stop.
Old Sep 17, 2004 | 06:49 AM
Ahsmo's Avatar
Ahsmo
Imakecopies
I hope who ever wired this thing wired the amp turn leds to the clarion deck rather then the ignition wire.
Did you use to not have a deck installed and still running running amps and speakers? If so, go the place you got it installed and tell them to re wire it.
Old Sep 20, 2004 | 06:39 PM
rotaryrocket7's Avatar
rotaryrocket7
The problem is the ground wire. Check to make sure the spot you've grounded on is clear of paint, should be bare metal. Make sure the connection is tight. This is almost always the reason for feedback of any kind.
Old Sep 20, 2004 | 08:09 PM
sal1's Avatar
sal1
Thanks guys, I'll recheck all the wiring.
Old Sep 21, 2004 | 06:16 AM
Daewoo's Avatar
Daewoo
which ground? the amp or the HU? I am having the same problem.
Old Sep 23, 2004 | 09:29 PM
rotaryrocket7
If you installed an aftermarket HU and used a wiring harness it is almost certainly the amo ground. When you wired the deck did you use wire caps, butt connectors, and did you solder? I never solder wires, and usually use wire caps. I would recheck the amp ground... Again make sure you have a clean bare metal surface and a good brass O-ring to connect. also make sure it's tight, use a lockwasher to make sure that it stays tight.. I bet this will correct it.
Old Sep 27, 2004 | 03:47 AM
sal1's Avatar
sal1
Thanks for the info
Old Sep 27, 2004 | 12:47 PM
Ahsmo's Avatar
Ahsmo
Imakecopies
did that fix it?
Obadabot
Jun 18, 2023 11:31 PM
3vilbunny
Jul 18, 2017 05:10 PM
kyin
Oct 15, 2015 05:54 AM
hulkout
Tuning
Sep 30, 2015 12:33 PM
