Head Unit Upgrade w/ OEM NAV
Old Nov 17, 2004 | 04:41 PM
arcada's Avatar
arcada
Default Head Unit Upgrade w/ OEM NAV
Does anyone know if there's a problem w/ the oem nav when replacing/upgrading the stock Bose head unit ?
Thx
Old Nov 18, 2004 | 08:03 AM
Shahrum's Avatar
Shahrum
I'd like to know this as well. If someone could please reply, I'd appreciate it!
Old Nov 18, 2004 | 08:41 AM
Shahrum's Avatar
Shahrum
I just got off the phone from a pretty lengthy conversation with the specialists from Crutchfield.com.
I was told that we're basically out of luck if we have a Bose HU and Navigation. The reason why is that the navigation connects to the Bose HU via a 14-pin connector. And without being connected to the Bose HU, it lacks ANY functionality.
However, at the same time, I was also told that it's possible to replace the factory subwoofer from behind the driver seat and replace it with a 10" woofer and to also replace the Bose amp. That's what I'm all about!
Old Nov 18, 2004 | 10:55 AM
Shahrum's Avatar
Shahrum
Ok now that I've been searching and reading around my350z.com, it seems many say that it's possible except that you'll lose the voice unless you somehow wire in an auxilary speaker. However, Crutchfield.com claims that you lose FULL functionality.
Can anyone confirm? If I lose voice, then so be it, I just don't want to lose my $2000 navigation!! Thanks!
Old Nov 18, 2004 | 02:45 PM
arcada's Avatar
arcada
Shahrum,
Do you know where the Bose amp is located ?
Old Nov 20, 2004 | 02:58 PM
Machupo's Avatar
Machupo
I had a completely custom system installed in my Z (it has the navigation system in it, as well)... the nav system still works fine, gives me popup directions / turns, etc... but you will lose the chick yelling at you when you miss a turn... damn, i miss her too
sorry to hijack, but this is a bit along the same idea...
are there any aftermarket DVD units or full computers that can take the place of the OEM unit so I can watch normal DVDs on the OEM display? Is there any software player that will then allow me to load the Navigation DVDs and run them? I imagine that the Nav DVDs are specially encoded for the OEM player. I have tried a normal dvd with no luck, so looks like i'm going to have to swap it out... any compatibility problems with the display?
thanks!
m_0g
Jun 3, 2021 10:05 AM
Vigman
Nov 17, 2015 04:34 AM
