Audio Builds Audio projects and builds from my350z members
Eclipse AVN5435 Installed - review - kinda long
Old Oct 10, 2005 | 04:32 AM
  #81
Kaitain's Avatar
Kaitain
Originally Posted by ZlleH
...You would think they would have something like that to prevent screenburns.
FYI: LCD's don't get screen burn, CRT's (Cathode Ray Tube) are the ones that get burn in.
Old Oct 10, 2005 | 05:36 AM
  #82
Cambelsoop's Avatar
Cambelsoop
i just installed this unit myself and everthing is awsome... serius is amaizng the only problem is there r too many stations to listen too. lol
i did run into a little problem. after everythign was set and done my airbag light is on.. all the connections r connected and everything is back where i took it from. im thinking i might have set soemthign off when i turned the car on when the passanger seat was out? ne 1 run into the same problem?
Old Oct 10, 2005 | 05:45 AM
  #83
Kaitain's Avatar
Kaitain
Hey Cambelsoop, I'd love to get your opinion of this unit as far as the Sirius portion goes. Also is there anything you don't like about it?
See this post:
https://my350z.com/forum/audio-and-video/146986-wanted-avn5435-sirius-pictures-and-impressions.html
Old Oct 10, 2005 | 11:12 AM
  #84
Cambelsoop's Avatar
Cambelsoop
https://my350z.com/forum/audio-and-video/147030-avn5435-please-help.html
Old Oct 19, 2005 | 07:35 PM
  #85
ZlleH's Avatar
ZlleH
Hey, rplink. I just got the avx2404 model. Did you need to buy a wiring harness to install the Eclipse head unit to the 350Z? Or does the head unit come with it's own wiring harness? Does Eclipse product go with nissan/350Z wiring or do you have to buy a wiring harness to make this work? Thanks. I'm going to be doing the head unit install myself so any help is really appreciated.
PS: did you do any grounding precautions?
Thanks.
Old Jun 20, 2006 | 12:36 PM
  #86
Cyp's Avatar
Cyp
anyone have pics of the speed sensor wire to tap into for the Eclipse AVN 5435? Does it require special brackets?
Old Jun 20, 2006 | 12:51 PM
  #87
Cambelsoop's Avatar
Cambelsoop
CYP i believe Paul350z had a write up and pointed out the speed sensor
nanotech
Oct 2, 2015 05:02 AM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
